Wireless$Bluetooth Amplifier SA100 with a pair of RK525 in-ceilspeaker with aimable woofer and tweeter
It is easy to group multiroom or multizone. If you want room 1 to work as master, you can drag the other rooms to room 1 to group multiroom mode. All the rooms will then play the same music in sync without latency. You can also make multizone on the application. If you want rooms 1&2 to make zone 1, rooms 3&4 to make zone 2, you only need follow the steps how to group multiroom, ie to group rooms 1&2 to make zone 1, and rooms 3-4 to make zone 2..., you can then play different music for different zones.
UI
why choose us?
About Us
Arylic is founded by groups of expert people with different skills from home audio and lifestyle new technology products. With more than 10 years of experience designing the product behind the scenes, we made the decision to make some products of our own team with our specialty, to make them good, value for money, good quality, maintain and update.
Learn more about our story>>QUESTIONS & ANSWERS
Have a Question?
Be the first to ask a question about this.
