Arylic 4 Pins Female to Female 22 cm, 2.5mm Connector Cable
Regular price $2.50
-99 in stock
📦Asia Stock Available Now
Due to exiting from the EU event, our EU warehouse is not support for shipping to UK and Northern IE. Will ship from Asia directly.
  • 1 Year Warranty
  • 14 Days Return
  • Free Shipping Over $90
  • EU/US/RU Warehouse
  • 24/7 Online Chat Support
Payment Method
  • DESCRIPTION
  • SPEC
  • Q & A
  • REVIEWS
Easier to Control your Audio
Detail Review
DIY your device
length 22 cm
Pitch 2.5 mm±0.05
Port Female to Female
Type 26 AWG
Model PH 2.0
Package Include 4 Pin x1
Usually Buy With
Up2stream Amp Series
Up2stream Pro Series
Up2stream Mini Series
QUESTIONS & ANSWERS
Ask a Question
  • The specs state PH 2.0 and pitch 2.5. That does no seem to align. When I look up PH2.0 connectors, they have 2mm pitch? Do we need to source PH2.0 plugs or XH 2.54 plugs?
    yes, it is our mistake in our offical website, they have 2mm, not 2.5
Software Comparison
Accessories Compatible
