Easier to Control your Audio
Detail Review
Strength your Wifi /Bluetooth Signal
Length | 20cm |
Frequency | 2400-2500MHz |
Gain | 3dBi |
V.S.W.R | <= 2.0 |
Impedance | 50ohm |
Connector | IPEX/Welding |
Type | RG1.13 |
Set Up | FPC Paste |
Package Included | Arylic WiFi/Bluetooth 20cm Internal Antenna x 1 |
Usually Buy With
QUESTIONS & ANSWERS
Ask a Question-
Will the Magnetic fields of a speaker impact the WiFi and Bluetooth signal?NO. we don't have such case yet. if yes ,you may adjust the location a little bit .
