News
How to Easily Setup Wifi Connection with Arylic Audio Systems
Wireless Home Audio System
For new players with Arylic, we will  launch a series of tutorial to feedback.
And if you want to see more tutorials about the other topics, welcome to leave a message to tell us.
Now let's get started!
So easy right?
Take your phone and try it, enjoy the music with Arylic from now on!
前後の記事を読む
The Resurrection of an Audioengine 5 with Up2Stream Mini
Up2Stream Mini V2 and Up2Stream Pro V2 is Available Now
9 コメント
Arylic
Arylic
Hi Kathy, as long as everyone is on the same network, everyone can use our 4STREAM APP to connect the device.
And no problem streaming with their Spotify, they can stream directly from the Spotify APP when connected to your network.
Arylic
Arylic
Hi NIall, You can choose B50 or H50 for the Bluetooth Transmission feature, and then you can connect to your powered speaker by Bluetooth. For other models, you need cables.
Arylic
Arylic
Hi David, you can refer to this video about the different connections:
https://youtu.be/v4bDrdMkd28
If it is still not available, you can send a mail to info@arylic.com for customer service.
Arylic
Arylic
You can try to reset the device to the factory settings or use the Lan cable for directly network connection.
If it still not available, you can send the mail to our customer service support info@arylic.com.
Includes your router, product model. Thanks
Ricardo Romero
Ricardo Romero
Hello
Short time ago, my internet provider changed the modem of my house, with a new one, that also transmit in 2.4G. My device used to work well with the old modem, but when I try to connect to the new one, I get to the “waiting for wifi connection” step, I write the password, but inmediatly goes back to “entering setup mode, follow the instructions on your phone”, in an eternal loop.
What can I do?
Thanks
Sanders Roland
Sanders Roland
Subject: Arylic S10
Hello,
Isn’t it possible only to use the inside wifi (SoundSystem_XXXX) together with the LAN connection without using an extra Wifi?
Thank you,
Roland
Kathy
Kathy
I have the SA100 set up with speakers and an optical audio in from my TV, and also use it to stream music from my phone, and it all sounds great.
Can you explain the best way for friends to be able to use this system?
Will they have to also download the 4STREAM app, and can the SA100 take instruction from more than one phone? Will the TV still play its sound through the optical audio cable if I’m not here with my phone & app to select that option? Can others stream their Spotify through the SA100?
Thank you for addressing my concerns.
NIall
NIall
When I set them up in different rooms , can I connect them to powered speakers via Bluetooth tooth or do I need to connect wires as with passive speakers
David Burnett
David Burnett
Unfortunately it doesn’t work for me – on step 5 it comes up with a spurious (and incorrect) message about incorrect password. Is there any alternative method to entering the password for my home network. I can get the device to work with the app by hardwiring it to the network (via RJ45), but even then I cannot enter the home WiFi SSID and password using the app settings.
コメントを書く
全てのコメントは、掲載前にモデレートされます
