WiFi&Bluetooth multiroom A50 amplifier with a pair of RK525 in-ceilspeaker with aimable woofer and tweeter
A perfect match, A great sound system
Small But Powerful,Brilliant Sound
Professional design Brilliant Sound
High Quality Audio Performance
Tuning Your Favorite Sound With Our EQ Setting (Remote Controller )
Multiroom & Multizone
With the line output, A50 can perform as a pre-amp, too. It’s a whole system audio output, no matter the sources from WiFi, Bluetooth, USB or DLNA. You can connect the line output to another amplifier to set up a larger house BGM.
Free Android &iOS App
Global Online Update with More Features and Stream Services
specification
BENCHMARK
It is easy to group multiroom or multizone. If you want room 1 to work as master, you can drag the other rooms to room 1 to group multiroom mode. All the rooms will then play the same music in sync without latency. You can also make multizone on the application. If you want rooms 1&2 to make zone 1, rooms 3&4 to make zone 2, you only need follow the steps how to group multiroom, ie to group rooms 1&2 to make zone 1, and rooms 3-4 to make zone 2..., you can then play different music for different zones.
UI
Video
How to stream music from Mac to A50 Amp by iTunes?
How to stream Spotify music from windows pc or mac to Arylic Wireless Audio System ?
How to play TV sound on Arylic Wireless&Bluetooth Amplifier A50
why choose us?
specification
BENCHMARK
UI
Video
why choose us?
QUESTIONS & ANSWERS
Ask a Question-
Helo! Can you tell me: can I control any of Your devices using network commands? web-morder or http API?Http api ,you can download that from our website.
