-Support Spotify, Amazon Music, and Apple Music via Airplay, Tidal, Deezer, and more.
-Multiroom streaming with versatile sources : WiFi, Bluetooth 5.0, NAS, USB disk, Micro USB DAC and Optical in.
-2.0 CH stereo class-D audio amplifier designed for home speaker systems applications.
-2x50W ultra power amplifier, HD audio quality, especially for bookshelf speakers and ceiling speakers.
-Gapless Playback, and lossless music with FLAC / MP3 / AAC / AAC+ / ALAC / APE / WAV.
In Stock & Ready To Ship:
Choose the plug type first
Small but Complete
Small≠Simple
Wireless and Wired Connection
Versatile Music Sources
Smart Features
Listening Wherever You Like
The A50+ amplifier is designed for home use, which can meet your music needs and bring you the best listening enjoyment, wherever in the living room, kitchen, bedroom, home office, home gym, garage, garden, or backyard.
Kitchen
Bedroom
Balcony
Living room
Meet Your Professional Needs
Easy to Set Up and Use
Step 1
Step 2
Step 3
Is there a standby mode on this stereo amplifier to save power consumption?
How many A50+ stereo amplifier I can connect to my network for multiroom at once?
In a multi-room setup, can you play different sources to different rooms at the same time?
How many speakers I can hook up to A50 wireless setereo?
Can I connect A50+ to my stereo amplifier as a streamer?
DC 12V-24V
2×50-W into a 4-Ω BTL Load at 24 V
2×30-W into a 8-Ω BTL Load at 24 V
Analog
RCA x1 / 2Vrms
Digital
Micro USB Input x1, Optical Input x 1
Analog
Sub Out x1 / 2Vrms, Speaker Out
Decoding
Up to 24bit/192kHz
Output
44.1khz/16bits, CD quality
20Hz-20kHz
0.03% / 91dB
TPA3116
0.2kg(0.44lb)
Learn MoreWiFi, Airplay 1, Spotify Connect, Qplay, Bluetooth 5.0, UPnP, DLNA
WiFi,AirPlay 2,Works with Alexa, Spotify Connect,Tidal Connect, Qplay,Bluetooth 5.2 aptX HD, UPnP, DLNA
2 x 50W
50W *2 (24V 4ohm)
30W *2 (24V 8ohm)
2x50W (4ohm 24V)
2x30W (8ohm 24V)
2x50W (8ohm 24V(Boost))
DC in 12V-24V
DC in 24V/4.16A, 32V(optional)
DC in 24V/4.16A
Sub(Optional)
Sub(Optional)
Sub(Optional)
Phono in
RCA Input (2 Vrms)
Phono Input (MM/MC)
Opt In
USB Type - C
Optical Input(PCM)
HDMI ARC(PCM ONLY)
USB Type C (USB DAC for PC)
Speaker output
Decode up to 192khz/24bits
Output 44.1khz/16bits(CD)
Output 48khz/16bits(CD)
Go Control App
A50+ WiFi Stereo Amplifier,
User Manual, Remote,
24V 4.16A DC Power Adapter,
2-1 RCA Cable,
2-2 RCA Cable, Screw Driver,
It has received 184 reviews.
