wifi stereo receiver
Led indicators of wifi stereo receiver
interface of wifi stereo receiver
expansion ports of wifi stereo receiver
wifi audio module
diy stereo receiver
stereo receiver with remote control
Up2Stream Pro V3 - Multiroom Wireless Receiver Board (No Amp)
Regular price $69.99 Sale price$59.99
Shipping calculated at checkout.
  • Build Your Wireless Streaming Audio System: Add WiFi, Airplay, Spotify Connect and Bluetooth 5.0 wireless capability to your DIY audio projects. Build a wireless speaker, wireless streamer or convert your tranditional stereo system into advanced wireless multiroom streaming system.
  • Bring Multiroom Capabilities to Your Next Project: Our wide range of Up2Stream boards are small enough to fit in all kinds of audio projects. Add an amplified streamer inside speaker boxes, or tiny receiver boards inside home theater amps. Their size and powerful connectivity brings new life to vintage gear and new ideas for your next DIY build. *All Arylic products are compatible with each other for multiroom installations.
  • Brilliant Sound Streamed Directly From Your Favorite Providers: Spotify, Amazon Music, Tidal, Qobuz, Deezer, Napster, TuneIn, Internet Radio, iHeart Radio, QQ Music, QQ FM. The Up2stream Pro V3 connects directly to your online streaming providers to play high quality audio, avoiding Bluetooth bottlenecks and compression.
  • Enhanced Up2Stream: The Up2Stream series gives you more options to add additional features to create more powerful custom projects. For example, it supports adding an ESS 9023 DAC to increase the sound quality, an S/PDIF In/Out board, Button Board, Volume Knob board, IR remote indicator board and more. You can find all the boards in Accessories.
    *The default S/PDIF setting of Up2Stream Pro V3 is S/PDIF Out, which can be adjusted to S/PDIF In via the ACPWorkbench tuning tool.
🚚 Shipping From
In Stock & Ready To Ship:
Choose the plug type first
Payments
$59.99
4th Anniversary Sale Will Ends In
0 : 0 : 0
Hr Min Sec
ANN200
ANN300
ANN500
Notice
Due to the Vacation on Oct 1 to 7 in our zone, our customer service will reply later.
Shipping from Asia warehouse will delay to Oct 8 since Oct 1. No influence with shipping from US, EU, AU, RU warehouse.
Wish you have great days and enjoy Arylic 4th Anniversary together!
Arylic Team
diy multiroom audio
Home stereo system
The Up2stream Pro connects directly to your online streaming providers to play high quality audio, avoiding Bluetooth bottlenecks and compression.
Enhanced Up2stream
The Up2stream series gives you more options to add additional features to create more powerful custom projects. For example, it supports adding an ESS 9023 DAC to increase the sound quality, an S/PDIF In/Out board, Button Board, Volume Knob board, IR remote indicator board and more. You can find all the boards in Accessories.
*The default S/PDIF setting of Up2stream Mini V3 is S/PDIF Out, which can be adjusted to S/PDIF In via the ACPWorkbench tuning tool.
audio receiver module
DIY Audio receiver
Easy to DIY
Unlike traditional DIY products, our DIY products are very simple, very easy to use and understand.
The print on the back allows you to see all features at a glance, and it also has all the most common interfaces. Anyone can look at the manual to start their DIY projects or connect their systems.
Unmatched Upgradability and Customization
Our boards have extensive add-on options ranging from enhanced DACs, digital inputs and outputs, and more. Use our proprietary ACPWorkbench software to customize and optimize DSP settings for each unit.
Choose boards with analog inputs to stream audio from turntables, USB input for Hi-Res audio files (PC or USB storage), and more. And all our boards come with Bluetooth 5.0 input.
wireless stereo receiver board
4stream
Powerful 4stream App
Choose your music source and control playback, set EQ, control multiroom/independent playback, manage playlists, control alarm clock, WiFi settings, update firmware and more... All the useful features you need in our free 4STREAM App for iOS & Android.
Up2stream Pro V3, Internal Antenna(WiFi), User Manual, 2pin Power Cable, PH2.0 4pin Cable, PH 2.0 7pin Cable.
package of diy audio receiver board
Spec
Based on 179 reviews
93%
(166)
6%
(11)
1%
(1)
1%
(1)
R
Robert Slais
Good product with bad strategy
Unpredictable device behavior because of forced update and without option to have last known stable firmware.
S
SM-D
Tolles Teil 👌
Ein gutes Board mit vielen Anschlußmöglichkeiten und einer hervorragende Integrierung.
D
David Hatfield
This unit works very well.
Am using it via the Ethernet RJ 45 port.
The Android App. and the webpage work well.
I ordered another unit with the amplifier.
dmh
S
Steve King
Great product
This was my fourth Arylic board purchase which pretty much completes my streaming system (at least for now)
I would recommend this system for streaming multiroom audio.
C
Christoph
Firmware has bugs for multiroom mode
At first i would like to say for single speaker application works very good.
If i connect two of them in multiroom mode, the one with the DAC has a defect volume control. If the Volume is off, both audio output are silence but If i raise the volume a Bit, the Up2stream with the DAC outputs full volume. The other one works as expected and has a regulated Volume.
For me i cannot use them in mutliroom mode at the moment and the sad thing is i got not even a response from the support since zwo weeks. Not per email, forum or chat.
P
Paul van der Horst
Nice multiroom receiver, good sound
Nice item. Works straight out of the box. The app is usefull but might be a bit more sophisticated. Right now I am ordening an extra app for further adjustments. I really like the Pro V3 and sound quality is way better then expected.
93%
(166)
6%
(11)
1%
(1)
1%
(1)
R
Robert Slais
S
SM-D
Tolles Teil 👌
D
David Hatfield
dmh
S
Steve King
Great product
C
Christoph
P
Paul van der Horst
