Up2Stream Mini - Multiroom Wi-Fi Streamer Board (No Amp)
-WiFi, Airplay, Spotify Connect, Bluetooth 5.0, DLNA, UPnP wireless connectivity support.
Features
Wireless Connectivity
Up2stream Mini supports WiFi and Bluetooth 5.0, allowing for easy streaming of music from various sources such as smart phones, tablet, laptop, and computer within your local network. Additionally, the device supports popular protocols such as Airplay, Spotify connect, DLNA, and UPnP, providing seamless wireless music streaming capabilities.
Lossless Audio
The Up2stream Mini is capable of supporting a wide range of lossless audio formats, such as FLAC, MP3, AAC, AAC+, ALAC, APE, and WAV. Additionally, it can decode up to 192kHz/24bits and deliver CD quality audio output of 44.1kHz/16bits.
Music Services Support
Versatile Music Sources
The Up2stream Mini offers versatile streaming options, allowing you to easily stream music from various sources such as music services, NAS, phone storage, SD card, and other 3rd-party apps that support Airplay, DLNA, and UPnP protocols. This provides you with a wide range of choices when it comes to selecting your preferred music source.
Additionally, the device comes with Bluetooth 5.0, enabling you to stream audio from your smart devices seamlessly. This means you can enjoy your favorite music on the go, without the need for any additional cables or devices. With its multiple streaming options, the Up2stream Mini makes it easy to enjoy high-quality sound from a variety of sources.
Multiple Interfaces
The Up2stream Mini comes with a range of ready-to-use interfaces, including a 3.5mm line out, micro USB audio input, and a plug for SPDIF out, IIS out, Line Out, LED Indicator, and ADC-key. Which enables you to create a flexible system according to your specific needs. With these features, you can easily connect your audio devices and enjoy high-quality sound without any complicated setup.
Multiroom/ Multizone
Enhanced Up2stream
The Up2stream Mini offers several optional expansion boards that can be used to enhance its functionality and performance. These expansion boards include the Up2stream SPDIF board, Up2stream button board, Up2stream ESS9023 DAC board, Up2stream IR extension board, and Up2stream volume knob board. Each of these expansion boards provides unique features and capabilities that can be used to customize and improve the performance of your Up2stream Mini device. You can find all the boards in Accessories.
USB Sound Card for PC
Once you connect the Up2stream Mini to your PC, it will be detected as a USB sound card. This allows you to stream audio from your PC directly to other devices connected to the Up2stream Mini. This feature provides a convenient way to extend your audio playback capabilities beyond your PC. Support both Windows & Mac PC.
ACPWorkbench Tuning Tool
The Up2stream Mini offers a range of communication options, including HTTP API, UART, and TCP commands, providing flexibility for users to integrate the device into their existing smart home systems or to develop custom applications. Get API files below in the download portion and check the cases in our forum.
With the 4STREAM app, you can rename your Arylic streaming device's WiFi SSID and Bluetooth name. The changes will stay even after a factory reset, until you change it again.
Optional Remote Control
The optional remote control is a useful addition to the Up2stream Mini, providing an easy and convenient way to control your music playback from a distance. Like play/pause, deep bass, adjust volume, and quick switch preset content from a distance.
*1. Warning: Up2Stream Mini must use 5V-1A DC input, higher voltage power
supply may damage the board.
*2. Up2stream Mini need ACPWorkbench tuning tool to switch the spdif configuration from spdif out to spdif in.
5V-1A 2 pin connector
5V-1A micro USB input
Micro USB Input
Analog:
3.5mm Line Out (1 Vrms)
Digital:
I2S Out,
*②SPDIF Out (44.1KHz)
20Hz to 20kHz
100dB @ 0dBFS, 1KHz
0.03% @ 0dBFS, 1KHz
Decoding
Up to 24bit/192kHz
Output
44.1khz/16bits, CD quality
Support NAS with DLNA support
55*45*12mm
150g
220mm Internal WiFi Antenna
4Pin 220mm PH2.0 Cable
7Pin 220mm PH2.0 Cable
2Pin 220mm Power Cable
User Manual
Device on:
Long press once: Switch off
Short press three times: Restore the factory settings.
Device off:
Short press: Switch on
⚪White-WiFi & network mode:
Solid- WiFi is connected
🔵Blue-Bluetooth mode:
Solid- Bluetooth is connected
🔵Blue-connect to PC
Not sure which one to choose? We selected all of our music streamer boards. Compare them and choose the best version for your needs.
① Up2stream Mini V3 need ACPWorkbench tuning tool to switch the SPDIF configuration from SPDIF out to SPDIF in.
5V/1A Micro USB
5V/1A Micro USB
5V/2A Type-C
Aux In(3.5mm Jack & Pin)
Aux In (Pin)
Spdif In (Pin)
Aux Out (3.5mm Jack & Pin)
DAC: Integrated
DAC: Integrated
RCA (RCA & Pin)
DAC: ES9038Q2M
I2S Out(Pin)
Spdif Out(Pin)
I2S Out(Pin)
Spdif Out(Pin)
I2S Out(Pin)
Spdif Out(Opt & Coax)
44.1khz/16bits(CD)
44.1khz/16bits(CD)
192khz/24bits (Hi-Res)
Optional
Optional
Optional
*①Spdif In Board
Spdif Out Board
DAC Board
Button Board
Volume Knob Board
IR Sensor Board
*①Spdif In Board
Spdif Out Board
DAC Board
Button Board
Volume Knob Board
IR Sensor Board
*②Spdif In Board
*②Spdif Out Board
*②Button Board
*②Volume Knob Board
*②IR Sensor Board
Display Panel
For single wireless projects
For Multiroom Projects
Build Your Wireless Projects
Wireless Speaker
Shared by Gary Ingram
Wireless Suitcase Speaker
Shared by Maarten Hekman
Upgrade Your Amplifier
Shared by Simon Baynes
DIY Multiroom Audio
Shared by Stefano
Is there a connection for triggering a relay to switch on/off an external amplifier?
Yes. but need to use our dsp tool ACPWorkbench to define the GPIO to work as relay.
Can I stream from YouTube ?
Yes you can stream YouTube by Airplay or Bluetooth.
Currently , Up2stream Mini only support connecting google home or Alexa via Bluetooth or line in.
It has received 270 reviews.
