mini preamp
led indicator of mini preamp
interface of mini preamp
size of mini preamp
connection of mini preamp
mini preamp with multi room control
mini preamp with remote control
Mini Preamp With Wifi & Bluetooth 5.0 S10
117 reviews
Regular price $99.00 Sale price $79.00
-291 in stock
📢This product is not available ship to Israel/UKraine, please contact Israel/UKraine distributor: Gerber Prime/Avero
🌍Deliver to worldwide from Asia
🚚Local delivery from US/EU/RU
📦Available in stock US✔ EU✔ RU✔ Asia✔
Check our shipping policy to know more details
  • 1 Year Warranty
  • 14 Days Return
  • Free Shipping Over $90
  • EU/US/RU Warehouse
  • 24/7 Online Chat Support
paymentmethods
  • DESCRIPTION
  • SPEC
  • Q & A
  • REVIEWS
Simply Stream Stereo Wireless
wireless preamplifier
Simply Stream your Stereo Wireless
Mini Preamp with Wireless Streaming
With S10 mini preamp Integrated, You can stream your audio wirelessly to your speakers by Wifi, Bluetooth 5.0, Airplay, DLNA & UPnP. And no matter where you are in your house, you can always take out your phone to play a song for you or your family. Like play a Bedtime Story for your Children, a love song for your wife, easy and wirelessly.
  • PCB of wirless preamplifier
    Compact Design
    Mini size smaller than your hand and simple design, these features make S10 easy to fit your home style and save space.
  • interface of wireless preamp
    Hi-Res Stereo Sound
    S10 Preamp support 16bit/44.1khz audio streaming and up to 24bit,192khz decoding which means you can stream with High Resolution audio wirelessly. Enjoy your high quality
  • multiroom preamplifier
  • Play your Whole House Audio Simultaneously
    Set a S10 preamp unit to each of your home stereo device as a streamer in your house, then you can group and control all the units to sync or play the sounds serparately at the same time.
  • Micro USB Sound Card
    S10 mini preamp is equipped Up2stream Pro V3 audio receiver board inside, so it can work as an USB DAC. You can directly connect it to a PC and stream PC audio digitally.
  • digital amplifier
  • Easy to Use
    If you are a Rookie with wireless audio system. S10 is your best choice to familiar with the wireless technology by economic way. Build up your wireless home stereo system only need 30 secs.
Stream All Music you Like
Stream your favorite online music such as Spotify, Amazon Music, Tidal, Deezer, Qobuz, Internet Radio, iheartRadio, Napster etc. Any time anywhere in your house with our 4stream App.
wireless preamplifier with Spotify connect
Upgrade All your Stereo into Wireless system
S10 min preamp is compatible to common stereo devices like Amplifier, Vinyl, active speaker and TV. By S10 preamp, you can streaming audio and control sounds wirelessly.
wireless preamplifier with home stereo
What's More
wireless preamplifier with digital output
USER INTERFACE & CONTROLS
LED indicators
White-WiFi & network mode:
Solid- WiFi is connected
Blue-Bluetooth mode:
Solid- Bluetooth is connected
Green-Line in mode
Red-USB mode
Yellow-connect to PC
Power Button
Device on:
Long press once: Switch off
Short press twice: Disconnect current WiFi connection and enter paring mode (WiFi mode); Disconnect current connected Bluetooth device (Bluetooth mode)
Device off:
Short press: Switch on
PC
iTunes/Musicbee/Foobar 2000
Remote
Remote Control Available
4stream App
Free iOS and Android App
AUDIO
Music Format
Audio Decode
Up to 24bit/192kHz
Audio Output
44.1khz/16bits, CD quality
Frequency Response
20Hz-20kHz
THD+N
0.03%
SNR
91dB
Audio Decode
Up to 24bit/192kHz
Online Music Service
Check here
Local Storage
GENERAL
Weight
0.2kg
Dimensions
116.2*64*22.6mm
Working temperature
Package Included
Main unit x1
User's manual x1
2-1RCA cables x1
Aux 3.5mm cable x1
Remote cotrol x1
5V1A Micro USB Power adapter x1
CONNECTIVITY
Wifi
5.0 SBC/AAC, 10M
Wired Connection
Streaming Protocols
AirPlay, DLNA, UPnP, Spotify connect, Qplay
INTERFACES
Power input
5V1A
Audio input
3.5mm mini jack(1Vrms)
USB Host
Antennas
WiFi/Bluetooth Signal
LED indicators
Green-Line in mode
Red-USB mode
Power Button
Device on:
Device off:
PC
Remote
4stream App
AUDIO
Music Format
FLAC/MP3/AAC/AAC+
ALAC/APE/WAV
Audio Decode
Up to 24bit/192kHz
Audio Output
Frequency Response
20Hz-20kHz
THD+N
0.03%
SNR
91dB
Audio Decode
Up to 24bit/192kHz
Check here
Local Storage
GENERAL
Weight
0.2kg
Dimensions
116.2*64*22.6mm
Working temperature
Package Included
Main unit x1
User's manual x1
2-1RCA cables x1
Aux 3.5mm cable x1
Remote cotrol x1
CONNECTIVITY
Wifi
5.0 SBC/AAC, 10M
Wired Connection
Streaming Protocols
INTERFACES
Power input
5V1A
Audio input
USB Host
Antennas
Download
Want to get a 30 to 50% discount on this item?
To Know More here.
QUESTIONS & ANSWERS
Ask a Question
  • I have two arylic A50 amps that each have speakers attached. I would like to add a record player that is not near either arylic. Could this S10 be used to connect the record player and hear the output wirelessly through one of the A50's on the same network? Thanks!
    Yes that is available, but I recommend you check the specs first that the audio input of S10 preamp is standard1vrms.
    If your player audio is too low or too high will cause low volume or distorsion.
    Then I advice you pick S50 Pro preamp which is 2vrms will better.
  • How many s10 units can be linked in multi mode? We are trying to hook up 6 to 8 of these units and we have been able to successfully link 4 in multi mode. On the 5th one it plays for a moment and then all music on all units in the group stop playing music. Could these be faulty? What steps should we try to test each unit?
    This may caused by different firmware etc.
    We need more info to figure out the issue, could you help us?(for each units)
    Please input this URL to your browser to help us get some device info:
    Replace 192.168.0.195 to your device IP, you can find device IP in settings>speaker info>device IP
    Then copy all the data you see in the browser to us.
    You can send to our customer service mail.
  • will there ba a software upgrade to AirPlay 2 in the futre
    That is hardware limitation.
    We will have higher spec model support Airplay 2 soon.
  • 1) The version of the S10 I have has a separate reset button next to the LAN port but I can't rest the device. I want to use the S10 over ethernet only but I am stuck on WiFi now that I have set it up. How do I reset the device? Oh, there is no reset button behind the AUX-In port either as indicated in the manual. Mabybe you should rewrite those instructions. 2) There is a definite lag between devices when paired together over WiFi. I also notice that the S10 doesn't quite keep up with the slave devices when used as the master streaming device even though it is less than 1.5 M (10') from the route , line of sight. What is the problem?.
    If you have new firmware of you device then the button feature is changed.
    You can check new features here.
    As for the sync issue, we need some info of your device, please follow the instructions below and send to info@arylic.com
    Or you can try new beta firmware here to improve it.
  • Does it need an internet connection or can you just connect via airplay
    You need to set up the device to your home network by our 4stream App.
    Then you can stream by Airplay directly.
  • Can a single audio input (AUX IN) be pushed to multiple mini preamp devices in multiroom mode? I would like to hook up my record player to one of these devices and have it play over several sound systems equipped with the Arylic mini preamp.
    Sure, on the master unit can input any kind of audio.
    So the master unit can under wifi mode, bluetooth mode, line in mode, USB mode. To stream all kinds of audio to other Arylic slave units.
  • ciao . il volume in uscita dal mio S10 è molto basso rispetto ad altre fonti ( CD , tuner , altri BT ) . è possibile regolarlo in qualche modo ?
    Controlla che l'uscita audio di S10 sia 1Vrms
    C'è un modo per regolare il guadagno del volume con il nostro strumento di tuning ACPWorkbench, ma si prega di notare non troppo alto che può causare distorsione.
  • Is it possible to totally turn off bluetooth and wifi, and use ethernet alone? I am highly EMF sensitive and use a wired network. I want a device that is not radiating anything. I am prncipally wanting to connect my lovely traditional hifi to internet radio. Thank you.
    yes our next frimware is available for closse the wifi when connect to ethernet.
    As for Bluetooth, just not to use then there is no bluetooth signal.
  • When you use the S10 as DAC for PC, do you connect to the micro USB port or the USB-A input. Thanks!
    To use as USB DAC for PC, you connect the micro USB port on the S10.
    Please make sure the USB cable you use can transfer data, since some USB cable is only use for charging power and cannot transfer data.
  • Your transmitter does not find my PSB headphones or my Edifier powered speakers what am I missing? Please help
    the  BT  of  our transmitter is passive  mode, it can not actively find  your personal  devices
  • What bluetooth audio codecs does it support?
    acc
  • Can I connect an old iPod Video 30GB on the USB port and get power and music through this port directly?
    The largest usb device we support is 2GB (1000 songs) and you can use the port to power
  • Please tell me if this configuration is fullynpossible. Send music from my mobile phone via Bluetooth to the S10, connect it with RCA plugs to the AUX IN in my Marantz amplifier, and some times to headphones, also with Bluetooth. From previous question, only 2 GB USB drive for audio files? Seems too low capacity. Thanks in advance.
    It seems to work, and we are actively promoting usb optimization and improvement
  • Does this unit play music in mp3 format stored in a USB stick, when I plug it directly to it?
    Yes, it supports mp3 format songs, the USB stick should not be bigger than 2 GB or 1000 song
  • Hi, It appears the S10 has no form of digital output?
    yes
  • Does it support Airplay 2?
    we don't support airplay2 currently, but our app 4STREAM can provide with the same functions as airplay2
  • Is it possible to configure the S10 with ACP Worbench?
    yes,it can connect to acpworkbench through  usb cable,please ensure the mode light is red
  • Can I connect S10 to MacBook with usb and hear Hi-Res audio files? Should I use footer2000 for playback?
    yes,the usbdac can play as a sound card, but i suggest you to use DNLA software to paly to get great experience, like foobar200 or musicbee both are ok
  • Hello, Does the s10 support Deezer Hifi? Thanks
    yes,  you could refer the diagram to know the device  https://www.arylic.com/pages/benchmark-1
  • Hello, do you have a Crestron Macro to Control your Player ? Thank you Lutz
    No .we have IP API for integration if you know how to do it .
  • Hi! When I buy the S10 preamp do I need to add the separate DAC extension board for better sound? I‘d like to connect the S10 to a powered speaker. Or does the DAC extension board only fit with the DIY boards?
    The sound feedback so far is quite good, you can have a try .If you want better sound S50 PRO is a better option ,which is built a good DAC inside already .
  • S10 is based on Pro v3. So I can add the SPDIF Out Board internally, but will not have a connection to outside. Right?
    Yes, better to get up2stream pro and spdif board and our protection case .
  • What is the version of the s10, it is already possible to use mini usb to connect a dac, and the old versions from 6 months ago?
    S10 is up2stream pro v3 built in ,support usb dac .
  • Does this support Spotify Connect with the Spotify Free version ?
    If you streaming via bluetooth ,it will work .
    But if streaming via wifi ,spotify policy is to use spotify connect ,which require premium account .
  • Hello, is the remote included with the S10 package from amazon us ? here it seems included but over there it is stated as optional. Thanks
    it included .
  • Does this support Spotify Connect?
    Sure, it support Spotify Connect.
  • I want to connect a Bluetooth speaker to the S10 - how do I add a Bluetooth speaker to the devices list? How do I send the signal to bluetooth speaker in another room?
    This product only support bluetooth RX, and does not support TX. So you can't connect speakers to it, we will consider this kind of requirement in future product designing. Thanks for the advice.
  • Does it support Amazon music HD right now ?
    We still talking with amazon right now .Hoping that can be integrated on beginning of 2021
  • Can you change the name of the device to something like “bedroom” or “lounge”?
    Yes, WiFi and Bluetooth name both can be changed the name you set .
  • Internet Radio (vTuner) has disappeared in 4STREAM application. I am using 4STREAM for Android on a SAMSUNG tablet and LG phone. The same thing happened on both devices. 4STREAM application was installed from Google Play. Internet Radio has disappeared from the service list, but Internet Radio radio stations previously set up are still in the preset list and are working properly. Internet Radio (vTuner) is a service for the reason I bought your product - ARYLIC S1. I kindly ask for help.
    The api changed, we will fix that and update soon .Thanks for your reminder.
  • I have a general questions about your products. Can two of your products, one act as a wifi transmitter and another as a wifi receiver? My plan is to connect an analogue sorce i.e. line out from a cd player to the transmitter and receive this analogue sound to the reveiver so I could output this to active speakers?
    Yes, you can , just using our app to play both device in Sync .then another device will get the source from first unit .To do that ,LAN is recommended .
  • Arylic S10 was used connected via home wifi (all in same wifi subnet) but always after Arylic restart device wifi Soundsystem_C21D has asked password for connecting to S10. Is there are way to get know this password or change it? Otherwise I need always to set factory reset for S10 to have clean S10 Sounsystem wifi without psw..
    S10 will remember your passoword and stay connected with your router .
    if you want to remove the password,you can go to app setting page ,which can turn off the password.
  • Will it support Amazon music HD. If not, are there any future plans
    Yes,talking with them right now ,but i can not commit a schedule because amazon do not give us that .
  • Can i connect my bluetooth headphones via the bluetooth on the S10 to listen streaming services? Thanks
    you can put S10 around you and use aux out .
    S10 bluetooth is receiver, not sender.
  • Can i stream by powerline adapter to extend wifi ?
    if everything in same IP range ,it's ok .
  • Does Spotify Connect work with a free Spotify account or do you have to pay for premium?
    Streaming via wifi all require spotify premium account ,same for all brands .
  • Can I attach a DAC to the USB?
    no. it's for playing music in usb pen drivers .but our V3 series already built USB DAC inside .
  • Can you play Plex Media Server to this device? Ideally without me enable DNLA. If only DNLA, is that easy to play music.
    Only DLNA, UPNP ,AIRPLAY supported ,not sure about what plex media server protocol use .
  • Can I use amazon music service
    Only USA users can use our amazon music right now .
  • this can work with tune in?
    Yes, it can work with tuneIn.  Our app 4stream has integrated tuneIn service.
  • Does it work with 220 volt?
    yes.
  • Can I play mp3 from a usb drive?
    Yes. even flac .
  • Can I play from my iPhone/iPad Apple Music?
    Yes, we support airplay
  • I have ans S10 and A50, I can stream YouTube audio from MV with apple devices via Airplay, but with android devices it just doesnt work. Any thoghts?
    For youtube, i would recommend you use bluetooth
  • I want to order the unit but wondered if it includes the 5V power supply/cable with a UK power socket?
    Yes, we include the plug in the package.
  • Hello, I bought one Up2stream Pro V2. Is possible have the rs232 protocol to integrate in a Crestron system? Thanks Best Regards Alessandro Zucchelli
    RAKOSO focus on home automation streaming solution .Future model will have that ,also IP control driver for all kinds of systems ,like Crestron ,Control4,Fibaro .....
  • Can I stream my computer system audio to the device?
    Yes, you can use itunes or footbar with plugin streaming your music wirelessly to our device .
  • Is it stereo? Once it joins my Wi-Fi network will I be able to connect to a Samsung tv that supports wireless speakers?
    It's stereo. after connected to your wifi network .If any app on your TV support DLNA, then you can stream to S10 or you can use your TV bluetooth ,connecting to S10 bluetooth ,then stream music .For TV program ,we recommend bluetooth ,latency is better.
  • Tell me about the enclosure. Is it plastic, or metal? Aluminum maybe?
    It is Aluminum casing with Acrylic plate on the top .we will update pictures on Monday .
Software Comparison
Accessories Compatible
4.9 Based on 117 Reviews
Write a Review
Thank you for submitting a review!
Your input is very much appreciated. Share it with your friends so they can enjoy it too!
Filter Reviews:
MT
09/02/2021
Michael T.
Malaysia Malaysia
Economical Wireless Solution
Good for those using old amplifier or streaming purposes. Sound was an acceptable quality with treble & bass functions. (Depends on amp & speaker) Need some improvement for the device infrared sensor the remote control sometimes not sensitive enough. Bluetooth sometimes fail to connect. The rest worked well. Overall this is good budget device with multiple wireless connection functions.
Massimo
Italy Italy
Ottima soluzione
Ho acquistato questo prodotto su un noto portale online dopo aver letto alcune recensioni. Confermo che il prodotto è ottimo. Lo utilizzo ormai da settimane con musica in streaming sia tramite rete Wifi sia bluetooth. L'App in dotazione è essenziale e molto funzionale permettendo di utilizzare le più note piattaforme di musica online. Inoltre c'è la possibilità di accedere ad altre fonti come ad esempio le web radio.
S
06/28/2021
S***v
RU RU
Goods norms, until the end has not yet checked, I will add time. Transportation is bad! The box was broken. Pribluda whole
Arylic Mini Preamp With Wifi & Bluetooth 5.0 S10 ReviewArylic Mini Preamp With Wifi & Bluetooth 5.0 S10 ReviewArylic Mini Preamp With Wifi & Bluetooth 5.0 S10 Review
A
06/25/2021
A***s
AO
E
05/31/2021
E***o
RU RU
Everything is good. The order came quickly enough. i order it for the second time. But this time, the seller saved on the package package. packed in a normal package without a navel. As a result, the box of the device came slightly cracked. Fortunately, the contents did not suffer. The little thing is not nice. The device itself is excellent. For this money it is better not to find. The sound reproduces very worthy. In the kit there is everything you need to connect. On the device itself, the firmware updates are regularly arrived. Convenient remote control and app for smartphone. I highly recommend to all music lovers. Thanks to Chinese comrades for the quality and inexpensive device!
A
05/06/2021
Anonymous
UA UA
A small box. Vials Gras Z flash drives. The streams of the servisi pratsut. Internet radios are present. The sound of the sound is outstanding on its own thunder. Cambridge is not a Sonos. Ale is good.
F
05/02/2021
F***z
CL CL
I arrive very fast and it is an excellent streamer at 1/10 of what a brand cost
DG
04/27/2021
Di G.
Italy
La soluzione ideale per ascoltare l'audio digitale su qualunque impianto stereo
Dopo diversi mesi di utilizzo continuo ed apprezzato da parte di tutta la mia famiglia, posso affermare che Arylic S10 �� un dispositivo ben fatto, di dimensioni contenute ed esteticamente discreto, utilissimo per ammodernare pressoch�� qualunque impianto audio adeguandolo alle tecnologie digitali. Dispone di una presa USB, per riprodurre brani memorizzati su memorie di ***** come file audio (mp3, flac, ecc.), ma anche di connettivit�� Bluetooth, WiFi ed ethernet, tramite cui si possono ascoltare flussi audio in streaming da dispositivi mobili, da server DLNA presenti sulla propria rete locale (il mio �� collegato al NAS di casa, un QNAP) o da diversi servizi internet come ad es. Youtube o Spotify. L'ascolto avviene collegando lo S10 via cavo tramite la sua uscita AUX ad un impianto di amplificazione tradizionale (il buon vecchio stereo) o a delle casse amplificate, ma pu�� anche pilotare via rete i pi�� moderni speaker wireless e gestire sistemi multi-room (preciso che quest'ultima �� una feature dichiarata che non ho ancora potuto testare). Il setup ed il controllo vengono effettuati almeno inizialmente tramite l'app 4Stream, ma poi tutto si pu�� gestire comodamente anche tramite il telecomando in dotazione con l'apparato (comodissimo, io ho usato l'app per eseguire il setup senza difficolt�� in occasione della prima connessione alla mia rete di casa, ma poi mi sono letteralmente "dimenticato" di essa). La qualit�� dell'audio �� molto buona e forse anche ottima se valutata in rapporto al prezzo, ma naturalmente non pu�� arrivare ai livelli della pi�� alta (e costosa) fedelt��. La dotazione a corredo dello S10 comprende l'alimentatore, il telecomando, un cavo audio stereo con due jack 3.5mm maschi alle due estremit��, un cavo audio stereo con un jack 3.5mm maschio a un'estremit�� e due spinotti RCA (bianco/rosso) all'altra, il manualetto di istruzioni. Un ultimo tratto da sottolineare �� la presenza anche di un ingresso fisico AUX in forma di presa jack stereo da 3.5mm che pu�� essere selezionato come sorgente da riprodurre, ovvero da re-inviare all'uscita AUX (tuttavia non sono certo che si tratti di una vera funzione "passthrough" senza alcuna elaborazione ADC-DAC); questa possibilit�� per me ha rappresentato un requisito fondamentale al momento della scelta di acquistarlo in quanto la presa AUX del mio impianto stereo era gi�� "impegnata" da un altro dispositivo (una TV) che ora ho collegato a tale presa sullo S10 in modo da averla ancora disponibile come sorgente. Infine, devo dare riconoscimento al customer service di Arylic di aver gestito con disponibilit�� una mia richiesta di assistenza (le mail scambiate si sono susseguite a distanza di alcune ore l'una dall'altra, ma penso che il gap temporale sia dovuto alle differenze di fuso orario).
А
04/20/2021
Александр
Russia Russia
Мини-предусилитель с Wi-Fi и Bluetooth 5.0 S10
Отличный аппарат за эти деньги! Звук вывел по spdif , поставив сзади RCA разъем. Выход звука 44\16 при любом входном сигнале - это надо учитывать при покупки. Максимальный входной 192/24 отрабатывает. Сравнивал по качеству звука с Primare NP5, так вот по качеству выхода с примаре- разницы нет! Единственное нет хромкаста, но за такие деньги понятно, лицензия на хромкаст денег стоит .Советую к приобретению...сам купил 3 штуки.
K
04/13/2021
K***k
PL PL
Can play "radio 357" and "Nowy Åšwiat" this can be helpful for polish customers. Sound quality can be better. It has lots of white noise and low output level so needs big gain
