Mini Stereo Amplifier
mini speaker amplifier
mini stereo
small stereo amplifier
mini speaker amp
smallest speaker amplifier
small stereo
speaker mini amplifier
A30+ 30W x 2 WiFi Mini Stereo Amplifier
Regular price$139.00
Shipping calculated at checkout.
A30+ WiFi mini stereo amplifier perfectly suited for your passive desktop stereo system and smaller space. The compact stereo amplifier and easy to use design makes it easy for everyone to get started quickly. Play online music service, online radio, local music files to your passive speakers by WiFi, Airplay, Spotify Connect, anytime in every rooms.
Model
🔌Plug Type
🚚 Shipping From
In Stock & Ready To Ship:
Choose the plug type first
Payments
$139.00
1
Small But Complete In Every Detail
A30+ mini stereo amplifier packs 30 watts per channel which is perfect to your desktop stereo system.
Enjoy the full functionality with wireless streaming: WiFi, Airplay, Spotify Connect, Qplay, DLNA, UPnP, Bluetooth 5.0 and full features of our 4STREAM App: Online music, Online Radio, EQ Settings, alarm clock and more.
So does includes the ACPWokbench tuning tool features. The compact stereo amplifier and sliver surface makes your desktop looks more clear and premium.
desktop amplifier
amplifier for desktop
Amplifier For Desktop
Best For Your First WiFi Stereo Amplifier
Our wireless streaming system is designed to be very simple, even for people who are not familiar with the electronics can quickly get started. There is clear step by step instructions in the app.
After the first setup of A30+ small stereo amplifier, you can stream directly from iPhone, iPad or Mac by Airplay or stream directly from Spotify both without app. The whole family can easily get started.
Play High Quality Audio Without The Hassle
Streaming by WiFi has stronger range signal and high quality audio transmission.
With A30+ mini speaker amp, you can stream anytime, anywhere with far distance from the device. Upgrade your listening experience far from Bluetooth streaming before.
multiroom audio system
Hook Up Whole House Audio
A30+ mini audio amplifier can play a different song in different rooms, or the same track in every room, or play some rocky music for whole house party!
Bring Hi-end music to every rooms and controlled by one single device.
Versatile Playing
Play from Amazon Music, Spotify, TIDAL, Qobuz, iHeartRadio, TuneIn, Napster, phone storage, NAS, USB stick,line in source, bluetooth source and more.
Stream any audio you want all in one A30+ small audio amplifier.
mini stereo amp
Personalize Your Sounds
A30+ mini stereo amplifier supports ACPWorkbench tuning tool which allows you do specific EQ adjustment, L/R balance, dynamic range and more. Set your favorite tune with different type of music.
A30+ WiFi Audio Amplifier, User Manual, Remote, 18V 4A DC Power Adapter, External Antennas (Bluetooth & WiFi), 2-1 RCA Cable, Screw Driver, 4 Pin Phoenix Connector (for speakers).
best mini stereo amplifier
SPECIFICATIONS
Based on 30 reviews
83%
(25)
17%
(5)
S
Sorin Vasiliu
Great product!
Michael Green
My first Arylic products
I am a qualified Audio Visual technician and discovered the Arylic products on a Youtube channel I follow (The Audiophile Man), and then researched the product range. I have initially purchased two A30+ units plus an S10 Streamer for evaluation. Installation was very easy and so far I am very impressed with the sound quality, stability and reliability. The 4stream app (free) seems to work really well and, again, so far seems reliable. In summary I will be expanding my personal system over the next few weeks and will then begin promoting the Arylic range to my customers as a cost effective multiroom solution. Thank you Arylic. Mike
J
Jason Jiskra
Exactly what I needed!
Looking to set up our outdoor speakers and needed the A30+ for the power and streaming options it provided!
A
Abraham Blenk
Amazing little amps
I have 3 of these, purchased over a few months. I initially bought an A30 as a proof of concept for my wireless sound throughout the house project. It worked very well, so I bought one more to see how they worked together. I was shipped an A50+ instead of the A30 I ordered, but it worked just fine, and I was able to sync the sound so that the transition between rooms was perfectly seamless. I then bought the last unit, an A30+, to complete the system, and everything is working well. The amps all provide excellent sound quality and volume, the setup is pretty straightforward, and the app that controls the system is fairly user-friendly. The only issue I have (and why I gave it only 4 stars) is that casting from my Denon WiFi receiver to the Arylic devices is very hit-and-miss, and this is something that I was counting on to work. Sometimes I can get it to work, and sometimes it just doesn't. I think this is more the fault of the Denon receiver than of the Arylic system, which seems to be focused on handling streaming services, which it does very well. It also works well with Media Monkey on my desktop and laptop computers. However, if the Arylic folks could figure out a way to connect more reliably to my Denon receiver, I would be very happy and I would give the system 5 stars.
L
Lukasz Kawalec
S
Sameer Govekar
Best amp on the price point
I had purchased this product after checking a lot of review.
But when i used it , the product actually has good value for money. The installation is smooth and the quality is awesome.
