M400 4-Zone Multiroom Streaming Preamplifier
Regular price$999.00
Shipping calculated at checkout.
  • Stream To 4 Zones - Independently, Or In Sync: Add Direct Streaming, Airplay, and Spotify Connect capability to your existing active wired speakers, amplifiers, preamps and recievers. Stream and control 4 different audio outputs at once, controlled wirelessly via our 4stream App.
  • Multiroom Audio System: Mix and match any combination of Arylic Streamers to create a custom multiroom system and play the same music throughout your home, send different sources to each room at the same time, or create your own custom-defined multiroom zones... All controlled via our 4stream App.
  • Brilliant Sound Streamed Directly From Your Favorite Providers: Spotify, Amazon Music, Tidal, Qobuz, Deezer, Napster, TuneIn, Internet Radio, iHeart Radio, QQ Music, QQ FM. The M400 connects directly to your online streaming providers to play high quality audio, avoiding Bluetooth bottlenecks and compression.
  • Stream Any Kind of Audio On One Device: In addition to Direct Streaming from Online Streaming Services, Airplay, and Spotify Connect, there are multiple digital and analog input and output ports allowing you to connect most of the audio devices in your home.
🔌Plug Type
In Stock & Ready To Ship:
Choose the plug type first
Payments
$999.00
4th Anniversary Sale Will Ends In
0 : 0 : 0
Hr Min Sec
ANN200
ANN300
ANN500
Notice
Due to the Vacation on Oct 1 to 7 in our zone, our customer service will reply later.
Shipping from Asia warehouse will delay to Oct 8 since Oct 1. No influence with shipping from US, EU, AU, RU warehouse.
Wish you have great days and enjoy Arylic 4th Anniversary together!
Arylic Team
The M400 is a networked 4-zone streaming preamplifier that allows you to directly stream up to 4 audio devices at the same time, per M400 unit.
The M400 supports the most popular smart home systems, Fibaro and Elan, and will be integrated with more smart home brands in the future.
4 zone streamer
Add Direct Streaming, Airplay, and Spotify Connect capability to your existing active wired speakers, amplifiers, preamps and receivers.
Home stereo system
The S10 connects directly to your online streaming providers to play high quality audio, avoiding Bluetooth bottlenecks and compression.
The M400 comes with optional mounting brackets for installation in standard 19" racks (1U height).
4 zone audio receiver
smart home system
M400 comes ready to integrate with Fibaro and ELAN Smart Home installations, with an RS-232 port to connect to your smart home control unit.
Integrate and control your M400 with your smart home programs.
M400, User Manual, Ethernet Cable, 12V 2A DC Power Adapter, Rack Mount Brackets x2.
Wireless 4 zone preamplifier
Spec
Based on 1 review
100%
(1)
K
Kurt Simon
Awesome
It was a difficult find. I’m using two RUSSOUND amplifiers to feed in ceiling speakers in my large home. The M400 is the perfect solution to what I was looking for. I am able to stream to 4 zones through the built in Ethernet and everything works perfectly. Use Pandora and you can stream to multiple zones with one single account. The 4STREAM app is awesome as well. Very happy with this purchase. Expensive, but it pays for itself with how easy it is to use
Based on 1 review
100%
(1)
K
Kurt Simon
Awesome
You may also like
