wifi audio receiver
Led indicators on WIFI audio receiver
interface of wifi audio receiver
expansion ports on wifi audio receiver
connection of wifi audio receiver
wifi audio receiver with multi room control
wifi audio receiver with remote control
Up2Stream Mini V3 - Multiroom WI-FI Streamer Board (No Amp)
140 reviews
Regular price $59.99 Sale price $49.99
-273 in stock
BLACK FRIDAY LIMITED
Get 20% OFF with code"ABF200" when purchase over $200 NOW!
Get 25% OFF with code"ABF500" when purchase over $500 NOW!
Up2Stream DIY Boards Make Multiroom Affordable & Integrated
Bring multiroom Wifi audio to every set of speakers in your home with our upgradable music streamer boards. Stream from Spotify Amazon Music, Tidal, Deezer and many other services.
More Info+
Use the included basic audio out, or add an SPDIF out board, or enhanced DAC and you're ready for HiFi streaming to any part of your multiroom network. If your setup already has power, choose our line-level out options. If you're looking for integrated amplification, we have you covered with 2.1, stereo, and mono options. All Up2Stream boards have included Bluetooth 5.0, and can stream any bluetooth, line-in or USB-connected sources to your whole home, any group of devices or a single unit.
The Mini V3
This tiny powerhouse makes multiroom streaming to every part of your home more affordable than ever. With a basic audio out, simple micro-usb power, and upgrade slots, this tiny package streams multiroom audio to powered speakers and amplifiers--for new builds or your current setup. Note: We recommend pairing this unit with our Enhanced DAC chip, or adding a digital out board if sound quality is important to you.
It's all about the App
Our free 4Stream iOS & Android app is your command center for your Arylic multiroom network. Set up your services and devices, create dynamic groups for different listening zones and more. See below for more details.
-Delivers worldwide from Asia, US, EU, & RU
See shipping options for details
  • 1 Year Warranty
  • 14 Days Return
  • Free Shipping Over $90
  • EU/US/RU Warehouse
  • 24/7 Online Chat Support
paymentmethods
  • DESCRIPTION
  • SPEC
  • Q & A
  • REVIEWS
Introducing Up2stream DIY Boards
  • multiroom audio receiver
  • One App for Whole Home Audio
    All our products use the free 4Stream app to integrate and manage your whole-home audio. Integrate streaming sources, or any connected audio channel into any audio setup. Spotify Connect users: Once your devices are setup with our app, use any phone connected to your Wi-Fi network to play to any device or zone via their own Spotify account. No special setup required for kids, spouses, or guests.
  • Play from Any Source
    Use Up2Stream boards as a USB DAC, and stream your library of digital files to any Arylic device or group. Or use bluetooth 5.0 from any smartphone and stream to a single unit, or any group of devices. Use analog or digital in expansion boards to integrate any audio source.
  • wifi audio receiver
  • wifi stereo receiver
  • Bring Multiroom to Your Next Project
    Our wide range of Up2Stream boards are small enough to fit in all kinds of audio projects. Add an amplified streamer inside speaker boxes, or tiny receiver boards inside home theater amps. Their size and powerful connectivity brings new life to vintage gear and new ideas for your next DIY build.
  • Unmatched Upgradability and Customization
    Our boards have extensive add-on options from enhanced DACs, digital in and outputs, and more. Use our proprietary ACPWorkbench software to customize and optimize DSP settings for each unit. Choose boards with analog inputs to stream audio from turntables, USB input for Hi-Res audio files (PC or USB storage), and more. And all our boards come with Bluetooth 5.0 input.
  • wireless audio receiver board
  • wifi audio streamer
  • Stream the Best
    Use your favorite music service: Spotify, Amazon Music (US Only), Tidal, Deezer, Qobuz, Internet Radio, iheartRadio, Napster and more. With Apple Airplay, you can bring any audio on your iOS device to every room in your house, just like any other music source with our 4Stream app--even with our Airplay 1 integration.
Up2Stream Grows with You
wifi streamer board
Write a review and save up to 50% off your purchase.Learn more.
QUESTIONS & ANSWERS
Ask a Question
  • Hi! Your product looks great. I want to install them (as many others have done) in some portable devices. I noticed that they have the ability to sync with each other in different rooms. What I want to know is if they can locally connect to each other? Ie P2P? I am specially talking about the V3 Mini… I want to build 2 portable speakers and have them connect to each other whilst I am away from my house - ie not connected to a router - a bit like a lot of portable speakers do.. like JBL connect, for example. Can the V3 mini do this? Thank you.
    For your needs, you can use your phone hotspot. Only need one phone to open the hotspot and connect both units to the hotspot.
    Then set 2 units under the multiroom mode.
    There is a limitation that you only can stream online source in our 4stream app, Airplay and spotify connect is not available by this way.
  • It’s ok with Dit2100msbt and Undock? Thanks!
    Sorry we don't support undock, but we have sleep timer which may achieve your goal.
    As for Dit2100msbt, yes you can connect from Up2stream Mini V3 by line out to the line in of your tuner.
  • Buon giorno, quale dispositivo Arylic potrei acquistare per il mio convertitore esterno? Vorrei collegare un M2Tech iFace DAC 32/384 USB, per farlo servirebbe una porta di ingresso usb asincrono. Grazie
    Spiacenti, non lo supportiamo attualmente. La porta USB è per la lettura della memoria USB.
  • Guten Tag Verfügen Ihre DIY Platinen über einen Schaltkontakt zum schalten eines Relais über die ein und aus Taste der Fernbedienung? Mfg Manuel
    Es gibt keine solche Funktion auf der Fernbedienung, aber Sie können Ihr Ziel mit unserem ACPWorkbench-Tool erreichen.
    Es gibt einen Teil über die Ausgabesteuerung, dass Sie einen Pin setzen können, um dies zu tun.
  • I have 2 mini v3 that won't connect in a multiroom arrangement. I've tried several times in the app, performed factory reset and still no success. I have noticed that they are running different firmware (4.6.328252.28 and 4.2.8826.21) if that makes any difference. What should I do to rectify this?
  • I bought 2 Mini v3. One succesfully connected to WiFi. The other two keep saying "The password you entered is incorrect". The password is identical to the one that succesfully installed. What's going on?
    Have you tried to reset?
    For technical issues, please send to info@arylic.com
  • 3.5 mm line out pin schematics?
    Top to bottom
    left channel-right channel-GND
  • Er der planer om at at opgradere I2S og Spdif output til 24bit/192KHz,
    Ja, vi planlægger en model med højere specifikationer, der har Airplay 2 og højere lydoutput.
  • Hi, planning upgrade my pioneer sx3900, do i have to powder on by pushing powder button every time please? i would like to mount inside the amp
    I advice you set the button out still. Due to the button is useful for reset and other purpose.
    But this won't need to power on every time by the button.
  • Puedo hacer "casting" desde youtube music a Arylic?
    Sí, actualmente sólo está disponible con transmisión por Bluetooth o Airplay.
  • i don,t understand... We have only an spidf out and no DSP right ? so i need another dsp dac to have a 3 ways crossovers Thanks a lot
    Because our device self is a DSP, you can change the direction of SPDIF through acpworkbench, and the process the signal by acpworkbench, includes crossovers/frequency/effect/pins function
  • Good evening, i'm trying to connect UP2stream pro V3 to a new network, without success, the led keeps flashing fast. Even by resetting the device the situation doesn't change. I have already successfully connected 2 other Up2strem. Thanks
    You can press the WPS button for at least 5 seconds ,then the white led will flash slow, you can pair the device via ble or wifi ap
  • Is your software an open source ? I mean can i use it for my own as i want to go onprod with a wireless speaker if yes can i have it if no how much it cost ,or at least to have a partnership with you Thanks
    You can  contact to our customer service department colleague,  their e-mail is info@arylic.com
  • I'm in the step of producing hi res audio speaker with your v3 module Do you have more spec about the DAC? Can i have the remote control code as i want to create a design one or perhap,s you can provide it or the manufacturer? thanks the best product in this category
    You can find the remote control code in our website, in resource place,
    as for more spec about the DAC, Is  the data sheet of the chip  ?
    This is the chip DAC document :https://drive.google.com/file/d/1wXn93IwQNwgzB3Sr9gl4z9CdjOf9kb3J/view?usp=sharing
  • What is the signal level output the module And the spidf is an input or output Thanks
    default  direction is output
  • Do I need additional.dac to crossover à 3 ways speaker? I have an ice power amplifier 125 also
    you doesn't need to add a dac crossover, because our device is a dac self , and you can adjust the frequency  and crossover in acpworkbench
  • Is it possible to configure the board for Mono Output? I.E. Mono L = Mono R = (R+L)/2.
    Of course, you can make it through  workbench
  • Default to Bluetooth mode with power on? This device seems to default to wifi when plugged in. Is there a setting or pin config to have this wake into bluetooth? Its annoying to go in the app and do this manually every time...
    what is your firmware version of your device? the default mode is the last you use mode,
  • I would like to audio out via USB to a USB connected DAC. Is this possible? Thanks. Tobias
    Sorry
         it  is  not  possible, because  the direction of  the  usb is input for Sound Card
  • Hi , if I add to the Up2stream Mini V3 a DAC board , can I use at the same time the 3,5 mm line out and the RCA DAC board output , and send the same sound to 2 differents Amplifiers ? Is there a delay between the 2 outputs ? Thanks. Eric
    Hello
            of course, you  can  use them  at the same time, 3.5 mm line Out is come from the DSP chip directly, and the DAC board transfer  spdif  signal  to simulation  signal, there   is no  delay
    with best regards
  • Hi, What are the exact functiond of the pins of the LIne Out connector (#9 on the user manual) To be more precise: What is the difference between GND and AGND? Thank you for clarifying....
    the number 9 is ready for DIY , AGND is for analogue signal
  • HI, can the volume control for the main device control the volume on Multi zone units or do you have to adjust them separately. Thank you
    Yes, you can ,when play in sync ,you click volume button on phone or remoter controller ,slave device volume will change as well.
  • Hi, is it possible to turn off the white LED via APP or the HTTP API when a Mini V3 is playing music via Wifi (Spotify Connect e.g.)?no HTTPAPI and can't do it on APP, but you can do this with remote control, it has a LED key to turn off/on the LED.
  • Does the device turn on when power is given? I want to use the Up2stream Mini V3 to add airplay to a car using the line in Aux. ideally the device would be hidden in the dash.
    yes , it will turn on when the power is given
  • I want to plug the board to my Car radio. It can read FLAC, WMA and mp3. Does the board play the music over USB? And can it receive commands like play/pause/next song over USB?
    sorry, it can use as USBDAC, it doesn't support USB, if you want the USB function , you can consider to purchase our advance product
  • Is the SPDIF out limited to 44.1Khz (what’s the bit rate btw)? I’ve a DAC that supports 24/192khz input over coax / spdif and I’d like to use the Mini to add streaming to it. It looks like Mini can decode 24/192 files but output over spdif will be limited to 44.1khz? Is it not possible to use the Mini as a bit perfect streamer and let an external DAC handle the rest?
    sorry, becuase of the limit of  the mcu , all digital signal passthrogh it will be treated with compress , so all output audio format is 44.1/16
  • Is there a possibility for an Auto on/off? I Start the Music from the phone and the Board Starts from standby und Play the Music?
    when it detects no music input after 30 seconds ,it will enter stand by mode ,so you don't worry , when it detct music input it will wake up
  • Is it possible to connect a speaker via bluetooth?
    You can connect mini to active speaker and streaming music via bluetooth .
    Bluetooth on mini is receiver ,not sender.
  • How does it work to take an Potentiometer for the volume? or how can i use the inputs for next and play?
    we have volume knob board in accessory page.
    And button board for those buttions .
    You can also try our remote controller to swtich input and next ,play.
  • When will soundcloud support be added?
    Target mid of 2021
  • Is there a connection for triggering a relay to switch on/off an external amplifier?
    Yes. but need to use our dsp tool acpworkbench to define the GPIO to work as relay .
  • The mini V3 has a 4 pin audio output: Left, Right, AGND and GND. Which GND do I connect where to my single supply active crossover which has +24V, +12V as virtual Ground and GND, which will be the same as GND of the Mini V3? Do I have to connect the AGND to the virtual Ground of my Xover?
    better connect to agnd, And you can use the acpworkbench tool to set the crossover in digital, it would be a better choice
  • does it work with google home?
    Via bluetooth will work .
  • Can I use the extension pack volume knob for switching the device on and of?
    The button board have standby function .
  • Can I use PIN 7 (3.3V) of PH2.0-7P to drive a relay? How much current does it deliver? What kind of stepdown converter provides the 3.3V?
    with acpworkbench, yes
  • Does the Up2Stream Mini V3 have a DSP integrated or is it only in the larger amplifier board? How is this DSP adjusted using a computer interface to set and forget or is it set manually on the app every time it is turned on?
    Up2Sream V3 series works with our dsp tool ACPWORKBENCH, in the tool, you also have the option to upload your EQ to flash and save it .
  • Is this Airplay 2 or the older original Airplay standard?
    We support airplay1 only,airplay2 will increase the cost quite much. airplay2 support multiroom control,which is supported by our app 4STREAM. What's more we can do multizone streaming .That means you can play different music from different source(such as usb,bluetooth,line in )in different rooms or same music in sync in all rooms,or you can group several rooms into Zone A ,some other rooms into Zone B, you can play different music in different zone as well
  • I want to use this to make a portable speaker, I can use it with Bluetooth only it I am away from my home network? Will this bridge to third-party Bluetooth or airplay speakers? This would be a very useful feature to link to existing speakers I own for an integrated experience.
    Hi, yes the board can work in Bluetooth mode when you're away from home network, but you better switch to Bluetooth mode first before you leave, and the device will remember the last input source for next booting. And if you've forgot and also you don't have a remote control, and also don't exported the button to change source. You can long press the button on board to trigger the WIFI pairing mode, and then connect to the AP of device with phone, and then in 4STREAM APP, you select the 'DIRECT MODE" and then change the source to bluetooth, and then you can connect to the device with bluetooth. Also, you can stream the music on your phone to the device via WIFI (but not the online musics, as there's no internet).
  • Does the App work for phone-local music playback if i only allow it in my firewall for LAN IP-Adresses? I want a privacy friendly multi room solution, thats why im asking.
    YES.
  • Can stream your tv sound (Line in) on another AirPlay device ?
    YES
  • If I use the WiFi/LAN connection will Roon find this and stream through it?
    Our device also can be a DLNA render ,if roon can stream to any DLNA render, then should works.
  • I want to put the mini into the metal enclosure of an existing hifi amp and fit an external stub antenna on the back panel. What connector is on board the mini and will both BLE and wifi work through that antenna?
    What you need is just get 2 external antenna sets from us ,which include everything you need .
    You need 2 because one for wifi ,one for blueooth ,the connector is IPEX type .
  • Can I connect a speaker directly to it or I need amplifier ? Does it support free as?
    If you speaker is an active one ,then you don't need an amp .
  • Does the device have an API? If so, can you link to the documentation?
    You can find our API files from the download section, which is locate at the bottom of our web site.
    Here is the link for you: https://www.arylic.com/pages/download
  • can i connect YouTube ?
    I suggest you use bluetooth connection if you want to stream audio from YouTube.
  • Hi, you need to have an Spotify premium account to connect with this device?
    Yes, you will need to have an Spotify premium account in order to stream from Spotify.
  • My unit only flashes blue which I have read means it is trying to do bluetooth. How do I switch it so it boots into wifi? I can't connect to the unit in any way.
    Please press and hold the power button before you plugin the usb power. After you plug in, keep on holding the button for 5 secs, this way it will force the device to go to wifi mode.
  • Do you always need to use the app once the setup is complete or can I choose multi room speakers from iOS phone menu and in Spotify app?
    Yes, you can use in the way you mentioned, no need app all the time .
  • After putting the unit into bluetooth mode, how do I switch back to WiFi/AirPlay? After switching into bluetooth in the app, there does not appear to be a way to turn off bluetooth or "prefer" WiFi. Is this what the ADC "Mode" key does?
    You just need to play anything from wifi source ,then it will come back .or you can use remote to swtich it back .
  • How do I put into bluetooth pairing mode? I want to connect my PC but I can't ever find the bluetooth device
    You have use app switching to bluetooth mode firslty ,then bluetooth will work ,then you can go setting to pair it.
  • Is this board able to play internet radio without streaming from your smartphone? Like Chromecast but for audio...without the need to keep phone connected.
    All sources played from interenet via wifi , no need of cellphone all the time ,all device will grab content from the interent directly and keep playing it .
  • Will there be a version with Dab+ integration ?
    Yes, technically ,we can do it .we will think about to make accessory for DAB,FM source in 2021.
  • ACP Workbench - can't find on arylic.com.
    It will be on sale within July .
  • What are the keys „NUM1“ until „NUM4“ meant for?
    NUM1 to NUM4, short press to play the preset playlist #1 to #4, and long press to set current playing playlist to the preset.
  • hello can I use one module only to have stereo sound, and interface with my stereo amplifier thanks
    Yes, one module can support stereo output in analog or stereo .
  • Hi, how do i connect to a dac via spdif?
    yes, you can wire GND+SPDIF to your DAC board according to our board words indicate .
  • Would it be possible in v3 pro series to change the name in the board? so the user only see the device as the new name?
    Yes, V3 can change wifi and bluetooth name by app .
  • Hi, are planning on support for soundcloud over WiFi?
    If we can get their API, we will make it .I can only say we will try our best .
  • Using I2S audio output, can the volume be controlled by the remote device while streaming through WiFi?
    Yes. All source can be controlled by our app and remote controller.
  • Is there an amp v3 version coming soon? What can we expect in the DSP? Multiband eq and time alignment?
    Yes, Expect to launch in June . an very easy and powerful DSP tool will launch together .
  • Hi, great to finally have bluetooth available on mini v3! does it support TWS (True Wireless Stereo) or can you only achieve stereo pairing through wifi on app ? It would also be great to add a master volume control as well as independent volume controls for groups on the app. Are you working on this ?
    TWS features is under developing ,once ready ,will inform all our users . Another big news we do not share much is ,there is a very power DSP audio tool realease soon ,will work with all V3 series .
  • Hi, is it possible to customize the name of the board? I mean when i look to the device with me phone can i change the name that I see from eg: arylic to the one that I prefer? Thanks
    Our App can change the name of each device to the name you want .
  • Hallo I have received your news on Mini V3.0. May we have the manual? Difference from 2.0? What do you mean with KeyBoard Board? Is it an optional? Regards. Max
    There should be manual inside, if not ,pls send mail to info@arylic.com .
    Keyboard board will be our accessory itmes in future .
  • I'm looking into setting up a DLNA server, can you recommend software that would setup well with this?
    You can try using foobar2000 with their UPnP/DLNA plugin, which is a freeware and works with our products.
    There is also Serviio media streaming server that will work with our products. They have a free version and a Pro version.
  • Can spotify play on more than one device at a time? Can you explain briefly how it is configured to support this.
    For spotify to do that ,it require family account, then you can stream like that.
    It's multiroom technology builit in ,similar to SONOS technology.
  • Are there plans to have native integration to support YouTube Music without using Bluetooth the same way you have support for Spotify?
    Yes, it's on the plan .but maybe Q3,Q4 of this year .
  • If I purchase two can I use them to create a stereo pair with good synchronization? If yes how good is the synchronization?
    yes, you can. You can set one as left one as the right channel very simple in our app.
    Almost no latency with wifi streaming when playing the music.
  • Does it work with airfoil?
    We just test and it can work with our system.
  • How can I stream music from site like https://moov.hk/intro/index.jsp ?
    You can only do that via bluetooth or airplay .
    if it's radio link ,you can stream via web browser with command below :
    http://deviceIP/httpapi.asp?command=setPlayerCmd:play:URL
  • Hi, can it play stream from Plex server?
    Sir not ,our system support streaming from our android,ios app ,bluetooth ,external input source ,such as line in . You can also used ituenes or 3rd party app support DLNA and UPNP.
  • I like to listen to radio stations that are not in apps. I like to listen to URLs directly, such as https://80s80s.hoerradar.de/80s80s-mweb-aac-mq. Is there a way to enter these streaming radio URLs directly into the app in order to get the music stream without using Tunein or another service to find these stations?
    you can use this command to play your own radio :
    URL is the link for the radio .
  • Is it compatible with the new Airplay 2 protocol (successor of Airplay)?
    our system only support airplay1 right now ,by itunes, you can still do multiroom control .for mobile device, pls use our android or ios app .
    Airplay2 will add the cost 100~200+ ,we may think about add it in future highend products .
  • 3.5mm line out also functions as line in?
    no .Pls check pro ,it have line in and line out .
  • Do this board could also work as a squeezebox server client.
    No .but we will check .we have apps integrate lot of streaming services already .
    Besides that ,support airplay,dlna, upnp ,spotify connect ,bluetooth .
  • Can a Google Home stream to this over wifi?
    Currently ,connecting google home to us via bluetooth ,you can make it work .
  • Hi, i recently purchased two Up2Stream Pro modules, and they are working wonderful up to about 45 feet inside the house with lot of obstructions. Due to the very long size of my house, i am not able to get the range at the last point. So i want to use an Up2Stream mini (v2) as an intermediate receiver-transmitter in between the existing two Up2Stream Pro modules. Also Is it possible to use these two differently types of modules with same 4stream app. Or is there any other way i can do it.
    Our system is similar to SONOS, all device is connecting to your home router including your cellphone .so the place you control with your cellphone ,if your cellphone is connecting to router well and our device is connected with router well ,then you can control . the only issue ,if somewhere ,the wifi signal is not well there ,you just need to buy some network device ,such wireless AP to cover there well .
    Then you can control well.
    One app support control all units to play music.
  • Can I use it with HEOS? I have Denon axr2400 with HEOS out. will this allow remote wireless speaker from Denon HEOS?
    Our system is not compatible with HEOS wireless control ,but if you using our system as an input source to their system ,it's ok .
  • WILL THIS WORK WITH HUBITAT OR SMART THINGS?
    We 're working on home assistant right now .
  • Its work with Deezer on android?
    Yes, both our android&iOS integrated deezer inside. you can use it right away .
    Pls note Cobblestone is not available for this feature right now .
  • Can I cast youtube music through it ?
    For youtube, you have to buy our models with bluetooth ,using BT to stream that .
  • Is there any plan on adding google cast support?
    Googlecast ,google require using very expensive chipset, so we do not have plan to implement googlecast yet.
    But you can control by Google home with voice through BT connection(up2stream pro have BT Mini doesn't),you can account for this video:https://youtu.be/n7uFCqxQh00
  • Hi, This module is good to integrate a Hifi stereo system connect to the AUX and/or connect for example to a 2.1 sound system? Thanks
    yes,we support line in(3.5mm),bluetooth,lan.
    And our system is 2.1stereo pair sound system.
  • Hi, do you have a complete documentation ? a technical documentation, for pinout, perhaps add a button. I don't see in dropbox. Thanks
    pls download the manula or read the product page pictures, we have full description there. We already upload the manual to the dropbox.
Software Comparison
Accessories Compatible
5.0 Based on 140 Reviews
5 ★
96%
135
4 ★
4%
5
3 ★
2 ★
1 ★
Customer Photos
Write a Review
Thank you for submitting a review!
Your input is very much appreciated. Share it with your friends so they can enjoy it too!
Filter Reviews:
K
07/10/2021
K***k
UA UA
I recommend this product
A great board is a streamer. Allows you to connect active acoustics on Bluetooth or Wi-Fi to a phone or other devices. For passive speakers will have to buy an amplifier. At the output we get a sound of good quality, but to improve the quality you need a separate DAC.
Arylic Wifi Audio Receiver for DIY Speakers Up2stream Mini V3 ReviewArylic Wifi Audio Receiver for DIY Speakers Up2stream Mini V3 ReviewArylic Wifi Audio Receiver for DIY Speakers Up2stream Mini V3 Review
C
07/08/2021
C***a
CL CL
Es una maravilla, pienso comprar más en el futuro. Una excelente opción para hacer parlantes al estilo Sonos. Llegó muy rápido. La conexión WiFi y BLE son estables. Recomiendo usar con un DAC para mejorar el sonido.
M***o
IT IT
Item arrived as expected, well packed in a hard box. The box contains 3 cables, one for type, an instruction manual and the device. The manual is very complete, are defined the characteristics of the device, the different uses and the steps to do to connect it. The app for interface is made well, this can be connected to multiple devices, once connected the card, you can check in both modes Bluethoot which mode Wi-Fi. The sound is good, reflects the tone is keen that the bass's songs. The board can be upgraded by applying, the connection is easy and intuitive, the app can use their own tracks or songs featured in the profiles of Spotify, deezer, tidal and others. Overall the product is very valid and can tramutare old stereo wired in new wireless. You can see the mode where you are located (bluethoot or Wi-Fi) according to the color of the led turned on the board or application
AS
07/05/2021
Alexander S.
Russia Russia
test
Thank you very much! Great quality, and great features. Best regards! Sincerely, Alexander.
E
07/01/2021
E***v
RU RU
It is very compact, an excellent option for multiroom systems.
G
06/25/2021
G***r
RU RU
Everything works. Will be a signal source for this wonderful device.
Muhammad
Syncing works relatively well and the app is easy to use. It is fun to program and learn how to use this with multiple devices as the instructions are easy to understand. It supports apple play and I used it to synch my phone via wifi and my desktop with a cable. Definitely worth it given the price.
A
06/08/2021
Anonymous
IT IT
It's a fantastic product that's easy to set up. The 4STREAM app supports the major streaming platforms: Spotify, Amazon Music, and TuneIn. I'm using it to make smart my old stereo. I'm very happy with this purchase.
D
06/04/2021
Dante
Amazing little machine for mutli streaming W/O lag, static. nothing but crystal clear audio!!!
I absolutely love these boards. I started with the S50 pro because of the ethernet port. A real connection always makes better audio out. I now how 3 v3 pro and 2 minis as well. One for each of my vintage amplifiers/receivers. I was a bit confused when I ordered the pro and mini boards until I read the simple instruction manual in the case....The only thing i can nag about is that they don't come with an enclosure or case of some kind. But they do sell them on their website at a reasonable price. I have one for each board until I can figure out how to install each one into the receiver/amplifier. The minis do surprising well not being hardwired into my network. I haven't had a single skip or lag in playback. The app could use some updating for androids but the airplay works awesome on apple. My ipad controls each board and is my remote. I only use the remote to power off the S50. I also use smart plugs for each receiver/amplifier and board. These are the best home audio streaming devices out to date and priced right! Just ordered another for a amplifier i bought at garage sale-together less than a hundred bucks at 65wpc :)
A
06/01/2021
Anonymous
RU RU
Delivered by courier from the Russian warehouse. Reliable packaging-the board comes in a plastic box. Included instruction and cables for connecting expansion boards. The fee works fine. Easy and fast to adjust. Sound good.
