True Wireless Bluetooth Earbuds With Mic and Charging Case
TWS Bluetooth 5.0 Hifi Stereo Audio Earbuds With Charging Case
- Bluetooth version: 5.0
Bluetooth protocol: HFP1.7、HSP1.2、HD Voice、Voice Prompts、
A2DP1.3、AVRCP1.6、IOS BATTERY STATE、MONITOR、Voice reporting、Multipoint
- Frequency: 2.4GHz,Class 2
- Charging input: 5V/1-2A
- Distance: 15 m
- RF radiate RF: 1600
- The sensitivity of receiving: -86dB/3M
- Size: Earbuds 41x19x25(mm);Charging Case 86x54x29.5(mm)
- Weight: Earbuds 4.6gx2 ;Charging Case 86g
- Battery Capacity: Earbuds 40mAH/ Charging Case 3000mAH
- Standby time:120h
- Call time:4h
- Charging time: Earbuds 1h/Charging Case 2h
- Color:
Package Include
- Earbuds x1
- Charging Case x1
- Micro USB Charging Cable x1
- User manual x1
- Different earplugs x 3
- Packing case x1
Warrenty
- 1 year warrenty
QUESTIONS & ANSWERS
Ask a Question-
Do they come in white?No. The black one is also good look and not easy to get dirty.
Can you use these as hands free to make phone calls? also the specification says it can only be charged 20 times?! can you clarify this?Yes, you can wake up the voice assistant to make a phone call.
Charged 20 times means the charging case with full power can charge the earbuds 20 times.
