Up2Stream Plate Amp 2.1 - Multiroom Wireless 2.1 Plate Amp
Sale price$99.00 Regular price$189.00
Save $90.00
Get 15% OFF
Discount code : beer15
  • Super easy to install with plate amp, build your wireless boombox without complicated skills.
  • Maximum 50W x 2 +100W powerful output for your 2.1 projects and audio system.
Support Together
✔Fast & Free Shipping
2.1 plat amp review
Up2stream Plate AMP 2.1
Up2stream Plate Amp 2.1 is a versatile WiFi and Bluetooth 5.0 2.1 channel plate amplifier that empowers you to effortlessly create your own top-notch wireless streaming speakers. This all-in-one solution boasts a full range Class D plate amplifier, delivering 50W for the left and right channels, along with an impressive 100W output for the subwoofer.
Equipped with various connectivity options, including a 3.5mm Aux input, optical input, and USB input for PC connection, the Up2Stream Plate AMP 2.1 ensures seamless integration with your audio devices. Fine-tune your sound experience using the intuitive volume, tone, and bass rotary knobs for precise adjustments.
Once connected to your home network, simply utilize our user-friendly 4Stream app. This powerful app enables you to effortlessly stream music from your mobile device, NAS, or popular online streaming services such as Spotify, Deezer, Tidal, Qobuz, and more.
With the ability to connect multiple devices, you can effortlessly create a multiroom audio system. Sync and enjoy the same music in every room or customize the experience by playing different tracks in different rooms.
Features
Wireless Connectivity
Up2stream Plate AMP 2.1 supports WiFi and Bluetooth 5.0, allowing for easy streaming of music from various sources such as smart phones, tablet, laptop, and computer within your local network. Additionally, the device supports popular protocols such as Airplay, Spotify connect, DLNA, and UPnP, providing seamless wireless music streaming capabilities.
Up2Stream Plate AMP 2.1 features an RJ45 Ethernet port for a more stable network connection. This allows you to directly stream music from your smart devices without having to go through the WiFi setup process using the app. This feature makes it super easy to get started and enjoy your music quickly and effortlessly.
Easy To Install
The Up2stream Plate Amp 2.1 is an amplifier board specifically designed for DIY enthusiasts. The board comes equipped with pre-wired connection ports, making it incredibly easy to install onto your speaker cabinet. All you need to do is connect it to your speaker, and you're good to go. This board is exceptionally user-friendly, saving you time and effort compared to other amplifier boards.
Powerful 2.1 Amplifier Board
With a peak power output of 50 watts per channel for two channels and an additional 100 watts, the Up2stream Plate AMP 2.1 has the ability to provide a impressive 2.1 home theater experience with powerful deep bass.
With the ready-to-use interfaces, streaming music is as simple as plugging in the power and connecting to a passive speaker and subwoofer. Unlike other audio boards, there's no need for soldering of pins before you can get started. This makes it incredibly easy and user-friendly for anyone to use.
Lossless Audio
The Up2stream Plate AMP 2.1 is designed to support a broad range of lossless audio formats, including FLAC, MP3, AAC, AAC+, ALAC, APE, and WAV. Furthermore, the board can decoding up to 192kHz/24bits, and providing high-quality audio output with a resolution of 44.1kHz/16bits CD quality.
The Up2stream Plate AMP 2.1 also delivers impressive sound with the TPA3116D2*2 amplifier chip used in its design. This chip provides powerful amplification to bring out the best in your audio.
Music Services Support
Versatile Music Sources
The Up2stream Plate AMP 2.1 offers versatile streaming options, allowing you to easily stream music from various sources such as music services, NAS, phone storage, SD card, and other 3rd-party apps that support Airplay, DLNA, and UPnP protocols. This provides you with a wide range of choices when it comes to selecting your preferred music source.
Additionally, the device comes with Bluetooth 5.0, enabling you to stream audio from your smart devices seamlessly. This means you can enjoy your favorite music on the go, without the need for any additional cables or devices. With its multiple streaming options, the Up2stream Plate AMP 2.1 makes it easy to enjoy high-quality sound from a variety of sources.
Multiple Interfaces
The Up2stream Plate AMP 2.1 comes with a range of ready-to-use interfaces, including a USB A audio input, optical input, speaker output and a plug for LED indicator, IR extension, and ADC-key. Which enables you to create a flexible system according to your specific needs. With these features, you can easily connect your audio devices and enjoy high-quality sound without any complicated setup.
Multiroom/ Multizone
This means you don't need to install any app or software to access the device's settings. Using this feature, you can easily set your preset content, EQ controls, playback options, and even update the device's firmware.
With this feature, you can quickly access and control your Arylic streaming devices, making it easy to enjoy high-quality audio with minimal setup time.
Enhanced Up2stream
The Up2stream Plate AMP 2.1 offers several optional expansion boards that can be used to enhance its functionality and performance. These expansion boards include the Up2stream button board, and Up2stream IR extension board. Each of these expansion boards provides unique features and capabilities that can be used to customize and improve the performance of your Up2stream Plate AMP 2.1 device. You can find all the boards in Accessories.
USB Sound Card for PC
Once you connect the Up2stream Plate AMP 2.1 to your PC, it will be detected as a USB sound card. This allows you to stream audio from your PC directly to other devices connected to the Up2stream Plate AMP 2.1. This feature provides a convenient way to extend your audio playback capabilities beyond your PC. Support both Windows & Mac PC.
ACPWorkbench Tuning Tool
Our proprietary ACPWorkbench software provides a powerful tool to customize and optimize the DSP settings of each unit of the Arylic streaming devices. This software allows you to adjust a range of settings, including L/R balance, frequency of every channel, pregain, and more.
By fine-tuning these settings, you can achieve optimal audio performance and tailor the sound to your preferences.In addition to DSP settings customization, the ACPWorkbench software also supports local firmware updates, define pins and configure other settings.
The Up2stream Plate AMP 2.1 offers a range of communication options, including HTTP API, UART, and TCP commands, providing flexibility for users to integrate the device into their existing smart home systems or to develop custom applications. Get API files below in the download portion and check the cases in our forum.
Functional Knob Control
The Up2stream Plate AMP 2.1 features 3 rotary knobs that enable effortless adjustment of volume, treble, and bass. However, these knobs also facilitate adjustments to the crossover frequency and mode switching. In addition to controlling sound characteristics, the Up2stream Plate AMP 2.1 provides versatile functionality for a customized listening experience.
Optional Remote Control
The optional remote control is a useful addition to the Up2stream Plate AMP 2.1, providing an easy and convenient way to control your music playback from a distance. Like play/pause, deep bass, adjust volume, and quick switch preset content from a distance.
Whether you're listening to music in your living room or in another part of your home, the remote control makes it easy to adjust your settings and enjoy your music to the fullest.*Need to use with Up2stream IR extention board and Up2stream button board.
Newest Firmware Version
Connectivity
WiFi:
IEEE802.11 b/g/n 2.4G
Bluetooth:
Wired Network:
Power Input
12V-24V/DC in
Audio Input
Analog:
3.5mm Line Input (1 Vrms)
Digital:
USB A Input
Optical Input
Audio output
Analog:
Speaker Out and Subwoofer Out
Other I/O Interface
LED pin connector
IR pin connector
Button pin connector
Amplifier Chip
TPA3116D2*2
Speaker Power
L&R 50W@4Ω + Sub 100W@2Ω BTL load at 24V
L&R 30W@8Ω + Sub 75W@4Ω BTL load at 24V
L&R 22W@4Ω + Sub 48W@4Ω BTL load at 19V
L&R 15W@8Ω + Sub 30W@4Ω BTL load at 15V
Speaker Impedance
4-8Ω (Stereo)/2-4Ω(Sub)
USB Host
Audio Channel
2.1(L+R+Sub)
2.1(L+R+Sub)
Mono
Music Service
2 x 50W + 100W
2 x 50W + 100W
100W(Mono)
2 x 50W(Stereo)
Analog Audio Input
Aux In(3.5mm Jack)
Aux In(3.5mm Jack & Pin)
Digital Audio Input
Optical In
Spdif In(Pin)
Spdif In(Pin)
Analog Audio Output
Subwoofer Out
Stereo-Aux Out(Pin)
Mono out(Pin)
Digital Audio Output
I2S Out(Pin)
Amplifier Chip
TPA3116D2*2
TPA3116D2*2
TPA3116D2
Audio Format(Up To)
44.1khz/16bits(CD)
44.1khz/16bits(CD)
44.1khz/16bits(CD)
USB Playback
ACPWorkbench
Remote
*①Optional
Optional
Optional
Knob Control
Yes(Volume, Treble, Bass)
Expansion Boards
ADC-KEY Board
Button Board
*③IR Sensor Board
Spdif In Board
*②Spdif Out Board
Button Board
IR Sensor Board
Spdif In Board
*②Spdif Out Board
Button Board
Volume Knob Board
IR Sensor Board
Suggestion
For Boombox
For Boombox
Build Your Wireless Projects
boombox
Powerful Wireless Boombox
Shared by Mundsen
diy boombox
Build Wireless Active Speaker
Shared by DaBu
wireless boombox
Customize Your Boombox
Shared by Paul Curtis
Compatible Accessories
ESS9023 DAC boardbutton board
Sale priceFrom $10.00
ACPWorkbenchDSP tool
24V adapter24V adapter EU
Sale priceFrom $5.00
Based on 15 reviews
60%
(9)
27%
(4)
7%
(1)
7%
(1)
P
Peter ERNST
Top
Top
G
Gonzalo Contreras Sánchez
aún no recibo mi compra
R
Reginald Tademy
Up2Stream Plate Amp 2.1 Converts Vintage Radio
The Arylic Up2Stream Plate Amp 2.1 worked wonders in reviving my vintage Westinghouse radio into a WiFi internet radio with crystal-clear sound. Installation was a breeze, and the ability to stream online music while retaining the radio's classic charm is a perfect blend of old and new. Paired with (2) 2 1/2" full-range speakers, and a low-profile 6" subwoofer, Arylic truly revitalized my radio and added a modern twist. Highly recommended for anyone seeking a smart yet nostalgic audio experience.
Judge.me YouTube video placeholder
S
Stefan
Genau was ich gesucht habe.....
Die Anlage aus meinem alten Auto zur Boombox gemacht. 13 cm Focal System und 20 cm Perless Sub. Die vollen Möglichkeiten ergeben sich erst mit Nutzung von ACPWorkbench Tuning Tool - damit konnte ich den Up2Stream Plate Amp 2.1 voll an meine Vorstellungen anpassen. Klingt super, hat druck und mit meinen weiteren Produkten von Arylic läuft ein Multiroomsystem hier absolut stabil. LED Statusanzeige wäre schön.
W
Wood4Sound
Overall a good amp
Overall a good amp. Three things should be improved. 1. The LED indicator is missing, so it is not clear what the source is. 2. You need to seal the connection holes in the panel, because air whistles through them when the subwoofer is playing. 3. It's 2023, make the same amplifier but with HDMI.
J
John Johnson
Noise
High noise floor during idle and music. According to Arylic this is normal behaviour. Otherwise good product.
