Up2Stream HD DAC - Airplay 2 High-Res Wireless aptx HD Audio Streaming Board(No Amp)
Sale price$149.00
  • AirPlay 2, multirooom streaming directly from your iOS system.
  • Spotify Connect and Tidal Connect Support, stream directly from your Spotify and Tidal App.
  • 192khz/24bits Hi-res music and FLAC / MP3 / AAC / AAC+ / ALAC / APE / WAV lossless audio format support.
  • Stream HD music with Bluetooth 5.0 aptX HD and ESS 9038Q2M DAC.
  • Plug and Play, quick connection, no pins soldering.
Support Together
✔Fast & Free Shipping
Up2stream HD DAC
The Up2Stream HD DAC is an advanced wireless audio streaming board that provides Airplay2, WiFi, Spotify Connect, Tidal Connect, Bluetooth 5.0 aptX HD, DLNA and UPnP connectivity. With this device, you can easily stream music from your smart devices, NAS, and various online streaming services such as Spotify, Apple music, Amazon music, Tidal, Deezer, and more.
The Up2Stream HD DAC is capable of streaming and outputting high-quality music in sample rates of up to 192kHz/24bits, ensuring an exceptional listening experience. Additionally, it comes with both analog and digital input and output, making it an ideal choice for building your own high-res wireless audio system.
Features
Airplay 2
With support for Apple Airplay2, the Up2stream HD DAC allows for direct streaming and multiroom playback of music from your iOS devices.
With Spotify Connect and Tidal connect compatibility, you can stream music directly from Spotify or Tidal without using our 4Stream app.
192khz/24bits Hi-Res Audio
Up2stream HD DAC supports 1:1 high-fidelity lossless 192khz/24bits audio output. What's more, the high-performance ESS 9038Q2M DAC plays a big role in sound quality. Enjoy high quality sound from high performance hardware with your stereo system.
Stream with HD Music
Up2Stream HD DAC is able to stream with Qobuz HD and Tidal HiFi to give you the true high-resolution audio experience. More HD music will be updated and supported in the future. Along with this HD music, it also supports Spotify, Amazon Music, Deezer, Internet Radio, iHeartRadio, Napster, and more.
Wireless Connectivity
Perfect to add dual band WiFi, Airplay 2, Spotify Connect, Tidal Connect, Bluetooth 5.0 aptX HD, DLNA and UPnP wireless capability to your DIY audio projects. Build a wireless speaker, wireless streamer, or convert your traditional stereo system into an advanced wireless multiroom streaming system.
Up2Stream HD DAC features an RJ45 Ethernet port for a more stable network connection. This allows you to directly stream music from your smart devices without having to go through the WiFi setup process using the app. This feature makes it super easy to get started and enjoy your music quickly and effortlessly.
Music Services Support
Multiple Interfaces
The Up2stream HD DAC comes with a range of ready-to-use interfaces, including a RCA out, coaxial out, optical out, and a plug for digital input, AUX input, AUX output, Display panel input and MCU GPIO input. Which enables you to create a flexible system according to your specific needs. With these features, you can easily connect your audio devices and enjoy high-quality sound without any complicated setup.
Versatile Music Sources
The Up2stream HD DAC offers versatile streaming options, allowing you to easily stream music from various sources such as music services, NAS, phone storage, SD card, and other 3rd-party apps that support Airplay2, DLNA, and UPnP protocols. This provides you with a wide range of choices when it comes to selecting your preferred music source. Additionally, the device comes with Bluetooth 5.0 aptX HD, enabling you to stream audio from your smart devices seamlessly. This means you can enjoy your favorite music on the go, without the need for any additional cables or devices. With its multiple streaming options, the Up2stream HD DAC makes it easy to enjoy high-quality sound from a variety of sources.
Multiroom/ Multizone
Enhanced Up2stream
The Up2stream HD DAC offers several optional expansion boards that can be used to enhance its functionality and performance. These expansion boards include the Up2stream Display Board, and other boards your need to wiring the correspond pins yourself: Up2stream SPDIF in board, Up2stream button board, Up2stream IR extension board, and Up2stream volume knob board. Each of these expansion boards provides unique features and capabilities that can be used to customize and improve the performance of your Up2stream HD DAC device. You can find all the boards in Accessories.
The Up2stream HD DAC offers a range of communication options, including HTTP API, UART, and TCP commands, providing flexibility for users to integrate the device into their existing smart home systems or to develop custom applications. Get API files below in the download portion and check the cases in our forum.
Optional Remote Control
the optional remote control is a useful addition to the Up2stream HD DAC, providing an easy and convenient way to control your music playback from a distance. Like play/pause, deep bass, adjust volume, and quick switch preset content from a distance.
Newest Firmware Version
Wireless Network
IEEE 802.11 b/g/n 2.4G & 5G
Wired network
Bluetooth 5.0 Qualcomm aptX-HD/SBC/AAC, 15M, BT Receiver
Power
Input:
5V-2A 2 pin connector
5V-2A Type-C input
Output:
5V 2 pin connector
50MA VC Out 2 pin connector: : +/-12V balance output.
① Up2stream Mini & Up2stream Pro need ACPWorkbench tuning tool to switch the spdif configuration from spdif out to spdif in.
Music Service
Power Input
5V/1A Micro USB
5V/1A Micro USB
5V/2A Type-C
Analog Audio Input
Aux In(3.5mm Jack & Pin)
Aux In (Pin)
Digital Audio Input
Spdif In (Pin)
Analog Audio Output
Aux Out (3.5mm Jack & Pin)
DAC: Integrated
DAC: Integrated
RCA (RCA & Pin)
DAC: ES9038Q2M
Digital Audio Output
I2S Out(Pin)
Spdif Out(Pin)
I2S Out(Pin)
Spdif Out(Pin)
I2S Out(Pin)
Spdif Out(Opt & Coax)
Audio Format (Up To)
44.1khz/16bits(CD)
44.1khz/16bits(CD)
192khz/24bits (Hi-Res)
USB Playback
ACPWorkbench
Remote
Optional
Optional
Optional
Expansion Boards
*①Spdif In Board
Spdif Out Board
DAC Board
Button Board
Volume Knob Board
IR Sensor Board
*①Spdif In Board
Spdif Out Board
DAC Board
Button Board
Volume Knob Board
IR Sensor Board
*②Spdif In Board
*②Spdif Out Board
*②Button Board
*②Volume Knob Board
*②IR Sensor Board
Display Panel
Suggestion
For single wireless projects
For Multiroom Projects
Build Your Airplay 2 Projects
AirPlay 2 system
Upgrade Your Old HiFi
Shared by Maurizio Cerpelloni
Airplay 2 streamer board
Airplay 2 Streamer
Shared by A.
AirPlay 2 audio receiver
Build Your Own Airplay 2 Project
Shared by MartinD.
diy AirPlay 2 audio
Customize Your Airplay 2 Amplifier
Shared by Froggy75
Compatible Accessories
Sale priceFrom $7.90
ESS9023 DAC boardbutton board
Sale priceFrom $10.00
oled displayoled screen
Based on 31 reviews
55%
(17)
19%
(6)
10%
(3)
3%
(1)
13%
(4)
Maurizio Cerpelloni
Woww..!!! Well Spent Money.€... !!!
I'm an happy user of an Arylic S50 Pro that I used to play Hi-Res contents from Amazon Music Unlimited with Android smartphones.
Used in BT mode 'cause I'ld use original Amazon App and above all , Poweramp Equalizer that allowed me a perfect frequencies setup.
Attracted by the new Up2Steam HD DAC , which promised better sound performance with a new ESS DAC and moreover "No Downsampling".. 1: 1 reproduction.
After some time I broke the delay and took it, completed with its beautiful case and replaced the S50 Pro .
Wooahhww ... !!! never purchase has proved more appropriate ...!
Used in Wi-Fi mode (here the difference with BT is noticeable), the effect does not resemble a Streamer replacement. Much more .. as if I had changed the whole HI-FI composition from good but basic brands to HI-END McKintosh compositions or similar ... !!!
My old Pioneer 6500 Mk.II Amp connected to a basic EQ Beringher FQB 800 and to KEF Q55 Mk.II standfloor speakers, with new Up2Stream HD DAC are able to give "Best of Themselves" with a Quality never heard before, turning into a New Life.
With Volume knob at 1 1/2 my Old Hi-Fi reproduces a real "Wall of Sound". Impressive power and clarity of sound, perfect channel separation, accurate balancing of output for different Instruments and Voices, details and clarity never heard before.
Creation of a Powerful and Detailed Soundstage with Voices & Instruments emissions perfectly distinguishable & integrated with each others .. !!!
Well .. listen Freddy Mercury singing "Love of my Life" closing my eyes... gives the impression of having "now" Queen in Concert directly in my living room .. !!!
Wouwhh .. Really Awesome ... !!!
My sincere congratulations to Fran who studied and implemented the creation of this "Jewel" and to Joy who, as always, took care of the order & delivery phases in an impeccable way.
If someone want to play his Old Hi-Fi with an unsuspected quality, never heard before...purchase of Up2Stream HD DAC Card is a real blessing, the most well-spent money with truly effective and detectable effects at first listening of any Know Song.
Only a prayer to Fran..add the direct access to Amazon Music App, as is for Spotify and Tidal yet.
Up2Stream HD DAC .... try it and .. you won't be able to do without it anymore . A True (Good) Addiction .. !!!!
![IMG_20220808_105749|666x500](upload://v7M5HIjH3uZR3lKuXFk8ZNr8eWs.jpeg)
J
Jörg Staub
Up2Stream HD DAC support
Well, the unit arrived and I immediately found a defective digital output. I opened a chat and it really needed several days to get the RMA. I shipped back and it arrived at the service point after one day. Now another week passed by, I heard nowthing from Arylic, neither facts about the defective board nor about a new one to get shipped to me - what do you thing about this service, now?
S
Sergey Vissarionov
Mark Greenberg
Dead Board, Twice
Received the Up2Stream HD DAC. It was dead on arrival. Good news I was able to get a replacement, but that unit was also DOA.
L
Lavinskiy Vladimir
Mike Vartanian
Works great out of box - wish it was more configurable
I purchased an Up2Stream HD DAC and am happy with it... It works right out of the box. Wish I could configure the I2S output settings though.
