H50 Wireless Stereo Amplifier
- Airplay2 amplifier which works with Alexa, supports Spotify Connect and Tidal Connect;
- Equipped with ESS9023p Sabre DAC and Qualcomm QCC3040 Bluetooth chip, supports WiFi 2.4/5G, and Bluetooth 5.2 aptX HD;
- 50W*2 stereo channels with load switching for 4ohms and 8 ohms passive speakers;
Upgrade Your Home Theater
Play music directly from your Apple devices, and stream music to multiple AirPlay 2 devices at the same time.
Smart Your Life With Alexa
Brilliant Sound Performance
H50 reproduce every detail of the music.
More Ways To Play
The Bluetooth transmitter feature on H50 gives you more options for listening enjoyment.
*PCM format ONLY.
H50 support both MC/MM, no worries about the compatibility.
Meet All Your Needs
Play From Your Favorite Music
H50 supports Airplay2 and works with Alexa, so you can sync sound with your other Airplay2 devices.
IEEE 802.11 b/g/n 2.4G/5G
2x50W @ 4ohm load at 24V
2x30W @ 8ohm load at 24V
4-8Ω
20Hz to 20kHz
>93db @ max power/<0.1% @ 1W 1kHz
24V/4.16A
Bluetooth:
2x Bluetooth RX, able to connect up to 2 Bluetooth transmitter devices.
Analog:
RCA Input (2 Vrms)
Phono Input (MM/MC)
Digital:
Optical Input(PCM)
HDMI ARC(PCM ONLY)
USB Type C (USB DAC for PC)
Bluetooth:
2x Bluetooth TX, able to connect up to 2 Bluetooth speaker or earbuds
Analog:
Speaker output
Decoding up to 192khz/24bits
Output up to 16bits/48kHz
Support NAS with DLNA support
2.23" OLED display panel
185x155x50mm
901g
Learn MoreWiFi, AirPlay 1, Spotify Connect, Qplay, Bluetooth 5.0, UPnP, DLNA
Yes (WiFi)
Stereo (L+R)
Stereo (L+R)
DC in 12V-24V
DC in 12V-24V, 32V (optional)
DC in 12V-24V
2 x 50W (24V/4Ω)
2 x 50W (24V/4Ω and 8Ω) (Boost)
2 x 80W (32V/4Ω)
2 x 50W(24V/4Ω)
Phono in
Phono in
Sub out
Sub out
Sub out
Micro USB in
USB Type - C
USB Type - C
44.1kHz/16bits
48kHz/16bits
48khz/16bits
Can I stream from Apple Music or Apple Podcasts?
Yes you can stream from your iPhone, iPad, Mac via AirPlay.
How can I transmit audio with aptX HD?
First, you must play music from sources supporting the aptX HD codec. Second, streaming to Bluetooth devices (Bluetooth headphones or Bluetooth speakers) that support the aptX HD codec.
This product is rated 4.4 of 5.0 stars.
It has received 28 reviews.
