GLOBAL FREE SHIPPING FOR ORDER OVER $90!VIEW DETAILS.
UP2STREAM WIFI&BT AMP BOARD - arylic
Regular price
$69.00
Sale price
$69.00
Quantity must be 1 or more
OPTION 1: WB50 WiFi&Bluetooth 4.2 Amplifier Circuit Board 69$
OPTION 2: WB50 WiFi&Bluetooth 4.2 Amplifier Circuit Board + 24V, A 84$
OPTION 3 : WB50 WiFi&Bluetooth 4.2 Amplifier Circuit Board + 24V,A Power Supply +Remote Controller 94$.
UP2STREAM WIFI&BT AMP BOARD WITH SPOTIFY AIRPLAY DLNA MULTIROOM 24BIT,192KHZ FREE ANDROID&IOS APP.
Up2Stream WiFi&Bluetooth amplifier board designed with top-class wifi&bt transmission chipset and a full digital amplifier class-d ic STA326 from ST. It can be powered by any DC voltage from 12V to 32v. This amplifier board is capable of outputting up to 80W per channel. It can drive 4Ω or 8Ω passive speakers.With our wireless streaming technology ,it support airplay ,dlna ,multiroom ,spotify ,and decode HD audio files directly ..
Features :
- Up to 80W per channel output .
- Powered by 12V to 32 DC voltage
- Full digital amplifier IC STA326 from ST
- 2.4G WiFi ,4.2 Bluetooth, 100M LAN Streaming option .
- Spotify,Tune in, iHeartRadio and more streaming service by update.
- Airplay ,DLNA ,UPNP supported
- 24bit,192khz HD audio and FLAC,WAVE,APE support
- Stream music from phone storage ,NAS,streaming services ,tablet .
- Multiroom streaming
- Free 4STREAM android and iOS app
- Remote Controller with full control commands .
Build Your Own Wireless Audio Project or System with Up2Stream Amp Board
interface
specification
AudioSystem
Amplifier Chipset: STA326 Full Digital Amplifier Chipset from STMicroelectronics
50W+50W @4ohm ,20Hz-20KHz,THD1%
Impendance:4-16ohms
Sample Rate: Decoding up to 24bit,192Khz
Audio Format: MP3 / WMA/ AAC / AAC+ / ALAC / FLAC / APE /WAV
USB Host x1stream music from usb files
Line in x1,RCA Breakable type
Line out x1,RCA Breakable type
Connectivity
2.4GHz 802.11 b/g/n with highly optimized WiFi Performance
10/100Mbps Ethernet
Bluetooth 4.2
Streaming Protocol
Spotify Connect ,Airplay ,DLNA,UPNP
Control Device
Smartphone,Tablet,PC(iTunes),Remote Controller(optional)
Music Sources
Spotify , iHeartRadio ,Tidal , Tunein , Napster , QQ Music , Ximalaya and more coming in the future ; Music Storted on Phone/Tablet iTunes music stored Iocally on your iSOt device or music stored on your Android device NAS (Network Attached Storaged) PIay from your home network NAS(DLNA Compliant)
App
Free iOS and Android App (Multi-language)
Power Supplier
Default power supplier :24V,6A
Support power supplier range:12V~32V
What's in the pacakge
Up2stream Amp Board X1
User Manual X1
Power Supplier X1 (Optional Package)
Remote Controller X1 (Optional Package)
High Quality Audio Performance
STA326
No Compression
24bit,192KHz
BIG POWER
Tuning Your Favorite Sound With Our EQ Setting (Remote Controller )
Stream Your Music Wirelessly
CLOUD
USB
NAS
SMART DEVICE
Pair Your Smart TV,Gaming Station by Bluetooth with No Latency
Multiroom & Multizone
Control By Any Device
Smart Phone
Smart Tablet
Windows PC
Mac
Beyond Your Expectation
Huge Music Resources
Free Android &iOS App
Global Online Update with More Features and Stream Services
BENCHMARK
It is easy to group multiroom or multizone. If you want room 1 to work as master, you can drag the other rooms to room 1 to group multiroom mode. All the rooms will then play the same music in sync without latency. You can also make multizone on the application. If you want rooms 1&2 to make zone 1, rooms 3&4 to make zone 2, you only need follow the steps how to group multiroom, ie to group rooms 1&2 to make zone 1, and rooms 3-4 to make zone 2..., you can then play different music for different zones.
UI
QUESTIONS & ANSWERS
Ask a Question
  • Oi, consigo montar um soundbar 2.1 com esta placa, Conexão entre a barra e o subwoofeer via wifi?
    Amp board only support stereo out . If you have a seperate subwoofer, you can connect soundbar by speaeker out and line out to your subwoofer.
  • Hello, does it have an PI to control on_off, mute and volume via a smart home system ? Thanks
    we have api for that ,except control on_off, for our amp model, we have auto energy saving technology ,when no music, then amp shut off .
  • Hi, I search one amplifier with 1x100w with mono. channel. is it possible to transform the 2x50w into 1x100w ? Thanks
    Sorry,our current model is not support mono.
