GLOBAL FREE SHIPPING FOR ORDER OVER $90!VIEW DETAILS.
Up2Stream Mini WiFi Audio Receiver Module, Circuit Board DLNA AIRPLAY Analog Output - arylic
Regular price
$32.99
Sale price
$32.99
Quantity must be 1 or more
WARNING: POWER ONLY 5V, 1A DC IN
Power supply more than 5V,1A DC input may damage the board.
DIY Wifi Audio Streaming Receiver Making Guide
bluetooth audio receiver board paypal
 Board dimensions  55.21x41.37mm
 Power supply  DC 5V-1A,2 pin
 Audio output  Analog,4 pin
 Frequency  20Hz-20Khz
 THD  0.009%
SNR  89dB
Audio decoding 24bit/192kHZ
 WIfi network  IEEE 8.2.11 b/g/n 2.4G
Speed(Max)  150M
Streaming protocol  Airplay/DLAN/Spotify connect/Qplay
 Multi-room  Yes
 Multi-room  Yes
 Music Format  FLAC/AAC+/ALAC/MP3/APE/WAV
Power input Cable  1 pcs 22cm cable included
 Audio output cable  1 pcs 22cm cable included
 Power PIN space  2.54mm
 Audio out PIN space  2.0mm
 WIfi Antenna 1 pcs,160mm
WiFi VS Bluetooth VS Others
SONOS Bluetooth Airplay Up2Stream Chromecast Audio
Android Compatible YES YES YES YES
iOS Compatible YES YES YES YES YES
Compatible with Airplay Streams(from Mac OSXiOS and iTunes) YES YES
DLNA YES
Lossless Audio YES YES YES YES
Play from NAS YES YES
Play from UPNP YES YES
Play from Online Service YES YES YES YES
Software number Playlist YES YES
Multi-Room YES YES
Standard Wi-Fi,with Full Home Netoork Range YES YES YES
Multi-Room, Expandable System (Synchronous) YES YES
Multi Streams from Different Sources YES YES
Multi-Zone Streaming from a Single Device YES YES
Left/Right Stereo Speaker Pairing YES YES
WPS Quick Connection YES YES YES
To upgrade your old audio system to WiFi Smart Audio System
Up2Stream is a mini WiFi audio receiver and decoding module. It can be easily integrated into your current active speakers or amplifiers to upgrade them into WiFi smart audio system with popular new features, such as multiroom, AirPlay, DLNA streaming, Spotify and internet radio playing.
Mini Size
Flexible to integrate into your current audio system
Up2Stream is coin size, you can easily find a place to integrate it into your current system and fix it easily by screws. You can DIY it within a few minutes.
Simple Interface
Simple interfaces, compatible with most existing audio system integration
Up2Stream interfaces are pretty simple. It can be used to easily upgrade most of your existing speakers or amplifiers to WiFi smart audio system.
Support HD Audio Streaming
Up2Stream uses latest WiFi audio streaming technology. It can stream audio files with sample rate up to 24bit, 192kHz, support popular lossless audio files such as FLAC, WAV and APE.
Easy Installation
To upgrade your old speakers into WiFi smart speakers within a few minutes.
Up2Stream, with 5V-1A DC power input and stereo signal output, can receive audio files streaming from phones, tables and PC, you can easily wire and solder the board to your speaker or amplifier board.
Control music in every room
Play same music in sync or different music in any room with your finger touch
More Features
Up2stream can do much more than you expected and more new features coming by global online update
WiFi Audio Receiver Module features
Massive Music Content
WiFi Audio Receiver Module music
APP Support For All Kinds of System
Specialized Designed Free Android and iOS app with global language support
Lots of 3rd party DLNA&AirPlay application available for Windows& Mac OS control.
why choose us?
QUESTIONS & ANSWERS
Ask a Question
  • Hi, This module is good to integrate a Hifi stereo system connect to the AUX and/or connect for example to a 2.1 sound system? Thanks
    yes,we support line in(3.5mm),bluetooth,lan.
    And our system is 2.1stereo pair sound system.
  • Hi, do you have a complete documentation ? a technical documentation, for pinout, perhaps add a button. I don't see in dropbox. Thanks
    pls download the manula or read the product page pictures, we have full description there. We already upload the manual to the dropbox.
