Subscribe below for the newest news and discount ! Global free shipping over $90
Up2stream Pro WiFi&Bluetooth HiFi Audio Receiver Board - arylic
Regular price
$49.99
Sale price
$49.99
Quantity must be 1 or more
WiFi and Bluetooth 5.0 HiFi Audio Receiver Board
A receiver support play music from Spotify,Airplay, DLNA, USB,NAS,Phone Storage.
Stream music wirelessly via network from all kinds of sources and without distance limitation and in high quality.Up2stream pro is a perfect hardware for music lovers to build or upgrade a traditional stereo audio system into a modern hifi smart wireless audio system.
-Stream via WiFi or Bluetooth 5.0
-Airplay,DLNA, Spotify Connect Supported
-24bit,192khz Decoding, Flac,Wav,Ape supported
-Multiroom&Multizone with multiple units
-Free Android&iOS app
-Spotify,Deezer,Tidal,Qobuz,Napster,iHeartRadio available
-Stream music from NAS,USB
-IIS for external DAC use
-Power supply: 5V,1A
-Network: WiFi or LAN
-Bluetooth 5.0
-Audio Output: 3.5mm aux and I2S
-Audio Input: 3.5mm aux in
-SNR: 91db
-THD: 0.03%
-Sample rate: 24bit,192kHZ
-Protocol: Airplay,DLNA,UPnP,Spotify Connect
-Demensions: 75mmx50mm
-App name: 4STREAM
Features
Stream Music via Network or Bluetooth
Stream music via network by WiFi or LAN with the app without distance limitation
Stream Music Without Compression
Stream music file up to 24bit,192kHz without compression via network.flac,ape,wave files supported
Spotify,Airplay,DLNA
Besides using apps,you can also stream by Spotify,Airplay or DLNA
Massive Streaming Music
Spotify,Tidal,Deezer,Qobuz,Internet Radio and more by online update
Bluetooth 5.0 Compatible
Longer distance, lower latency, better sound quality
Multiroom&Multizone
Multiroom and Multizone features is supported if using with multiple units .Play same or different music in each room
QUESTIONS & ANSWERS
Ask a Question
  • When you link multiple Up2Stream Pros, can you disable the wifi and bluetooth of the other devices? Also, is it possible to rename the bluetooth device? instead of having it show 'Upstream_D8B3'?
    WiFi will be hidden after connected ,or disabled if using LAN  bluetooth is off ,it broadcast and work when you swtich to BT model when you swtic that inside app . In the app ,you can change the room name, bluetooth name can not be changed right now .
  • Hi, I want to connect my Onkyo AV receiver to wireless rear surround speakers. Can I use these devices?
    IF you receiver got line in port ,then it will work .Imagine our device is a CD player,which already included thousands of CDs and you can control everything by apps !
  • Hi, Does the Up2Stream Pro also supports Stereo Pairing (via Wi-Fi)? Kind regards, Lode
    Yes, our all products support 2.1 stereo pair system
  • Hi, is it support Pioneer FlareConnect™?
    Currently ,it only support dlna ,airplay ,spotify connect or stream via our app .
  • Hi, Can this module also stream the line-input to other Up2Stream modules in a multiroom setup?
    Yes , line in ,usb ,bluetooth all can restream to other up2stream unit ,all our products support that .
  • Hi I want to build a media streamer for hifi (I have a NAD M51 DAC and I use Spotify). The Up2stream Pro WiFi&Bluetooth HiFi Audio Receiver Board seems like a good start but I wonder if the module is sufficient to feed a good DAC for high-end audio playback? If so, what does it take in terms of other components i.e transformers, connections, etc.?
    Yes, the biggest advantage for wifi streaming is fit the hifi demand . The components will make a little difference. Everybody have different definition about that.
    I recommend you buy a basic model to try ,to feel yourself.
  • Hello, is it possible to controle the on_off, mute and volume with a API (smart home system) ?
    we have api for that ,except control on_off, for our amp model, we have auto energy saving technology ,when no music, then amp shut off .
  • Hello, what are the bluetooth codecs supported? SBC, APT-X, APT-X HD, LDAC?
    It's middle end bluetooth 5.0 with good sound performance.
    but not CSR model ,which is not with those high-res codec .
    To play high-res files, absolutely,we recommend you use our app to stream via app .which is even better than APTXHD.
    For future highend model ,we may use APTX HD chipset ,but price would be different .
    old models still can group with future new models.
