Up2Stream Plate Amp 2.1 - Multiroom Wireless 2.1 Plate Amp
plate amp
wireless plate amp
subwoofer plate amp
Regular price $189.00 Sale price$99.00
Shipping calculated at checkout.
Get 15% Off with code DAD15
  • All In One Solution: Add WiFi, Airplay, Spotify Connect, and Bluetooth 5.0 wireless capability to your DIY audio projects. Build a wireless boombox effortlessly or convert your traditional 2.1 system into an advanced wireless multiroom streaming system.
  • Bring Multiroom Capabilities to Your Next Project: Our wide range of Up2Stream boards are small enough to fit in all kinds of audio projects. Add an amplified streamer inside speaker boxes, or tiny receiver boards inside home theater amps. Their size and powerful connectivity bring new life to vintage gear and new ideas for your next DIY build. *All Arylic products are compatible with each other for multiroom installations.
  • Create Powerful Wireless 2.1 Speakers And Amplifiers: Up2Stream Plate Amp 2.1 has a powerful 50W x2 output with 4Ω passive speakers at 24V on the stereo channels and a 100W sub output with 2Ω passive subwoofers at 24V, Hear and feel the striking, powerful stereo sound and deep bass all around your house. Accepts 12V-24V power input and 4Ω-8Ω speakers, 2Ω-8Ω subwoofer.
  • Position Your Boombox Anywhere: You can place your boombox anywhere in your house and wirelessly stream deep bass throughout the house.
  • Brilliant Sound Streamed Directly From Your Favorite Providers: Spotify, Amazon Music, Tidal, Qobuz, Deezer, Napster, TuneIn, Internet Radio, iHeart Radio, QQ Music, QQ FM. The Up2stream Plate Amp 2.1 connects directly to your online streaming providers to play high quality audio, avoiding Bluetooth bottlenecks and compression.
❤️We will donate $1 USD dollar of your every order to help the refugees in Turkey-Syria earthquake. Thank you for doing charity with us!
Express Shipping is $20.
Shipping Location:
✔Fast & Free Shipping
✔Online 7/24 Expert Support
Payments
1
Our wide range of Up2Stream boards are small enough to fit in all kinds of audio projects. Add an amplified streamer inside speaker boxes, or tiny receiver boards inside home theater amps. Their size and powerful connectivity brings new life to vintage gear and new ideas for your next DIY build. *All Arylic products are compatible with each other for multiroom installations.
Create Powerful Wireless Boombox And Amplifiers
Home stereo system
Easy DIY Solution
The compact and thoughtful design allows you easily DIY your projects without any worries about wiring, expansion boards, or other electronics.
Simply install the complete plate amp assembly in your custom speaker chassis directly.
Unmatched Upgradability and Customization
Our boards have extensive add-on options ranging from enhanced DACs, digital inputs and outputs, and more.
Use our proprietary ACPWorkbench software to customize and optimize DSP settings for each unit. Choose boards with analog inputs to stream audio from turntables, USB input for Hi-Res audio files (PC or USB storage), and more. And all our boards come with Bluetooth 5.0 input.
Up2Stream Plate Amp 2.1, External Antenna(WiFi & Bluetooth), User Manual, USB Cable, Speaker Cable x3.
Based on 10 reviews
50%
(5)
30%
(3)
10%
(1)
10%
(1)
J
John Johnson
Noise
High noise floor during idle and music. According to Arylic this is normal behaviour. Otherwise good product.
p
peter billik
Super amplifier
Very good quality of sound, no hiss, and low distortion.
R
Reid Bakken
DIY kits
These kits are pretty sick but I see a few major flaws for the DIY-er. This one specifically, lacking the little LED is almost impossible to connect. Secondly, the power supply wires should be accessible out of the back of the plate. I think alot of DIY'ers will want these to be portable battery powered units, mine is powered by a makita, but I did have to find a 5mm power adapter and cut it off, and plug it externally to the plate.
Overall, I am really stoked on this product, and I have about 6 total units. Not sure that I would buy this again over the Up2stream 2.1, as that has the remote control and LED built in.
D
Dan
Great 2.1 amp for DIYers
Do you want an all in one solution to stream music to your drivers? Then the Up2Stream Plate Amp 2.1 is a serious candidate. You just need to solder the supplied wires to the speakers and fix the plate to the cabinet. Once you power it and connect it to the mobile app you have a ton of option to make it sing: USB DAC, Bluetooth, DLNA, or one of many online audio streaming services that are included in the app. You can even listen to your obscure online radio that isn't listed by typing the URL.
The integrated DSP is a powerful tool to tune your sound: crossover, BSC, EQ, virtual bass, stereo widening, etc
With all this great features of course there are a few shortcomings:
- like for example it has a webserver with a nice interface that sometimes does not update. (eg. eq settings)
- connecting it to the Wi-Fi can be troublesome sometime because there's no status LED. Be sure to buy the led / button extension board; I didn't know about it at the purchase time
- I would like a pairing mode for the Bluetooth; right now it can be paired without any code. Imagine somebody connects to the speaker from outside the house and plays at full volume in the middle of the night :|
- sometimes it's easier to press a button then opening an app, so the remote would be more convenient - I also didn't know it was available as an accessory but I plan on buying it.
There's always something that needs improvement on a device and the more feature it has the harder it is to make everybody happy. I'm sure that the engineers at Arylic will try to improve things in future firmware updates.
H
Huỳnh Bá Quang
I still have not received the goods because it has not been cleared through customs, will I have to pay extra tax?
P
Paul Curtis
Great Amp For Easy DIY Installation
A great Amp for DIY (only thing I would prefer is something visible ie inbuilt LED to see whether you are on wifi/bt/aux etc.)
Plenty of power for an average sized build and without all the complications of having to solder etc etc
Judge.me YouTube video placeholder
