📢Subscribe Now To Get Mail Discount!
WiFi and Bluetooth 5.0 HiFi Stereo Amplifier Board Up2Stream amp 2.0
Up2Stream amp 2.0 WiFi and Bluetooth 5.0 HiFi Stereo Amplifier Board - arylic
WiFi and Bluetooth 5.0 HiFi Stereo Amplifier Board Up2Stream amp 2.0Wifi&BT Amp Board Up2stream Amp 2.0
Regular price
$99.00
Sale price
$69.00
30 Days Return ⏱
Free Shipping Over $90.00 🚚
Quantity must be 1 or more
BUY NOW AT Amazon US
  • DESCRIPTION
  • SPEC
  • VIDEOS
  • REVIEWS
  • Q & A
  • DOWNLOAD
 WiFi and Bluetooth 5.0 HiFi Stereo  Multiroom/Multizone Amplifier Board With Spotify, Tidal, Pandora, Airplay, DLNA, Upnp Support
WiFi & Bluetooth 5.0 Stereo Amplifier Board
The stereo amplifier board that supports music play from Spotify, Deezer, Qobuz, Tidal, AirPlay, DLNA, NAS and phone storage.
The Up2Stream amp 2.0 WiFi and Bluetooth stereo amplifier board streams the music wirelessly from all kinds of sources without distance limitation in high audio quality. This Up2Stream stereo amplifier board is great for music enthusiasts to build their own wireless audio system or upgrade their existing regular audio system to be WiFi and Bluetooth enabled.
-WiFi 2.4G and Bluetooth 5.0
-Support Spotify connect, AirPlay and DLNA
-24bit, 192kHz decoding
-Audio formats: FLAC, WAV, APE, AAC, MP3, etc
-Spotify, Deezer, Qobuz, Tidal, Napster, TuneIn and iHeartRadio etc
-Free Android and iOS application
-Global online firmware update
-Power input: 12-26V
-Network: WiFi and Ethernet RJ45
-Bluetooth 5.0
-Speaker power
-2×50-W into a 4-Ω BTL Load at 21 V
-2×30-W into a 8-Ω BTL Load at 24 V
-2×15-W into a 8-Ω BTL Load at 15 V
-THD+N: 0.03% @1kHz 50W+50W 24V-4Ω
-Speaker Impedance: 4-8Ω
-Dimensions: 110x80x20mm
-Protocols: Spotify connect, AirPlay, DLNA and UPnP
-App name: 4STREAM
Features
Stream Music via Network or Bluetooth
Stream music via network by WiFi or LAN with the app without distance limitation
Stream Music Without Compression
Stream music file up to 24bit,192kHz without compression via network.flac,ape,wave files supported
Spotify,Airplay,DLNA
Besides using apps,you can also stream by Spotify,Airplay or DLNA
Massive Streaming Music
Spotify,Tidal,Deezer,Qobuz,Internet Radio and more by online update
Big Amplifier Power
Up to 50Wx2CH@4ohm output with 21V Power supply
Multiroom&Multizone
Multiroom and Multizone features is supported if using with multiple units .Play same or different music in each room
UP2STREAM AMP2.0 Specifications
Connectivity WiFi IEEE802.11 b/g/n 2.4G
LAN RJ45 single 10/100m
Bluetooth 5.0
Freqneucy Response 20Hz-20kHz
Power Input DC 12V-26V
Speaker Output 2X50W into a 4ohm Load at 21V
2X30W into a 4ohm Load at 24V
2x15W into a 4ohm Load at 15V
Audio Output 4 pin line out (L, GND, GND, R)
Audio Input 3.5mm aux in (0dB @ 1Vrms)
4 pin line in (L, GND, GND, R)
USB 2.0 host
IR IR (NEC protocols)
SNR 91dB
THD+N 0.03%, @1kHZ 50W+50W 21V 4ohm
Music Format FLAC, MP3, AAC, AAC+, ALAC, APE, WAVE
Sample Rate Decoding upto 24bit, 192kHZ
Protocol Airplay, DLNA, Spotify Connect, Qplay, UPnP
Streaming Sources Spotify, Deezer, Tidal, Qobuz, iHeartRadio, Napster, Internet Radio
App 4STREAM available in App Store and Google Play store
Control Devices iOS and Android based devices, PC(iTunes or Foobar2000), Remote Controller
Key Software Features Multiroom & Multizone streaming supported
All sources support restream to other unit in sync
Stereo Pair
Network Reset Button inside aux in port
LED LED indicator for work status
Accessory Bluetooth antenna, WiFi antenna, User manual, phoenix speaker connector
Dimension 110 * 80 * 20mm
Weight 130g
  • Up2stream Amp 2.0 And Up2stream Pro Diy RGB LED Wooden barrel Speaker-English
    ✔️Up2stream Amp 2.0 unboxing
    ✔️Up2stream Amp 2.0+Up2stream Pro Diy Portable Speaker Tutorial
    ✔️Up2stream Amp2.0+Up2stream Pro Sound Performance
  • Up2Stream Amp 2.0 Review And Setup Tutorial(4K)-Engilsh
    ✔️Up2stream Amp 2.0 Review
    ✔️Up2stream Amp 2.0 Setup Tutorial
    ✔️4stream App Guide
    ✔️Remote Control Showcase
    ✔️Up2stream Amp2.0 Sound Performance
  • Up2stream Amp 2.0 Sound Test Live Show-Portuguese
    ✔️Up2stream Amp 2.0 Sound Test With Live Show
    ✔️Up2stream Amp 2.0 Sound Test With Different Mode
  • Up2stream Amp 2.0 Upgrade The Traditional Radio Player-English
    ✔️Up2stream Amp 2.0 Unboxing
    ✔️Up2stream Amp 2.0 Upgrade DiY Tutorial
    ✔️4stream App Showcase
Arylic | Video
QUESTIONS & ANSWERS
Ask a Question
  • Could i stream audio with line in to other speakers ? and how big or long is the delay ? I Would like to stream audio to other speakers.. Other systems have a delay of 1-2 seconds...
    Yes, our system can do that .Latency via network is also 1-2 secs .
    If just swtich line in to current output device, almost no latency .
  • I want to use two amp boards in two speakers, making them active speakers. I want to set those speakers up as a stereo pair. Is this possible and how should I wire them?
    Yes, Up2stream amp2.0 can meet your needs.
    For how to wire up the speakers, you can refer to the videos.
  • How can I use the GPIO port? Is there any way to program functionallity?
    we already programmed and support lots of command already. We keep this for future accessory use .
    If you are busienss buyer ,pls contact us via email to get more info .
  • Are there plans to add support for Google Play Music or Youtube Music when it replaces GPM? Are there plans for a slightly more powerful amp, maybe 2x 75W to give those that will use 8ohm speakers a little more head room? How is volume controlled when the Aux In is used? Is it always controlled by the app? (i will try a record play connected to a pre-amp, then that will be connected to your amp, just trying to figure out where I will get volume control for when I play records) How do you change inputs without the remote? Primarily I'd like to know how to select the aux input when I start playing a record. Thank you,
    Yes, have plan for bigger power amp and new streaming services.
    Line in and all other sources can be swtich via our remote controller or app .same for volume control
  • Can you program the name of the Bluetooth connection that shows up during pairing?
    For MASS order ,we can make the firmware with the bluetooth customer want .
  • Is there any chance to access the EQ settings for permanent adjustment including all sources? I know CSR chips are capable of basic DSP stuff like Compressor, EQ, etc.. Would be great, since it is way more complex to do it with passive components. If not, is there any solution where you can get a proper DSP (for example ADAU1701) inbetween the preamp unit and the Amp itself?
    We have an MCU on board, which includes DSP there .On app and remote controller, you can adjust EQ setting for all sources. You may check if it is enough for you .For ADAU1701,we may used it on future productcs .
  • Is it possible to use the Amp without the APP? Pair the Bluetooth device etc.
    For 1st time setup ,app is required ,after that ,if you don't want to use app ,you can use bluetooth ,airplay ,DLNA or remote controller ,which is not required to use with our app .
  • Is there a particular enclosure you would recommend for this board?
    You can choose the material that won't interfere with the signal.
  • I'm wanting to use 3-6 of these, each with a hardwired ethernet connection to my router/LAN, to create a multiroom system that is controlled from iPhone / iPad that connects to the network by WIFI. Spotify / Pandora / Amazon / similar streaming services will primarily be used, but will also hook one up to an existing stereo receiver (line in, line out connections) to have the ability to push legacy media (LP's, CD's, etc.) through the system. Doable? Also, what power supply do you recommend for this unit?
    It sound like a smart and mature idea. Luckily ,our system fit all demands well.
    For receiver, i recommend you our S50 Pro .
    For power ,you may use our power supply or you can check if some in-wall central power suitable or not  ,such as meanwell .
    All our amp need is DC from 12-21V .
  • Is there any integration with Alexa to turn streams off or automatically play based on voice command?
    no .we would suggest you use our remote ,i think it's even easier than alexa ,which still need to do by several step and wait for around 30secs . our system is more designed to use with apps ,you can browser music and find the music easily .and you can also preset the content ,click one button to play the playlist you want .
  • Can you buy a larger power supply and share it amount a couple of the amps? If you get a 15 amp supply could it support 3 boards shared?
    if there is any central power ,can generate multiple 15V power suppply ,then you can make this work .we have customer project ,installed 20 pcs in a case .
  • Hi, Is this board capable to play the stream from rj45 interface(if this is connected în the same LAN with the audio server) ? Thank you!
    Sure. that's why RJ45 is there .you can also call our system network audio streaming system .
  • ís the 4-pins speak-out plug included in the package? if not, how to order it?
    Yes, it's included .You can use it right away when you get it ,if you have right power adapter.
  • What should be the current value in the DC power adapter ?
    5A
  • I'm wanting to setup a multi-room soundsystem using speakers I already have that's sourced from a pc and router. Can I connect this board to my network without using a phone app?
    Yes. it support bluetooth ,dlna ,airplay .all of these do not require our app to work with ,except for the 1st setup . For pc, you can use bluetooth or itunes 's airplay or dlna streaming to our system . or footbar is another option .
  • hi, i am planning to use this amp for in ceiling installation and thus i will not be able to turn power on and off everytime i start or quit listening to music. has the amp the ability to notice when the mobile app trys to connect to the amp and then switch power on or off? i can imagine that this problem could be easy solved via the remote control for ONE amp, but i will have around 6 amps in my house's ceilings because i wanna do multiroom. do i have to switch power on for every single amp via its remote control then?
    Our amp has power saving technology ,when there is no music playback ,it will go to power saving automatically and very low power consumption ,only keep the wifi running .When music coming back ,all system will come back right away .So you don't need to worry the power consumption and turn them off and in this way ,you can enojoy music rightaway everytime you play something .
  • Is it possible to set this board up as mono out? I want to build an active speaker where the tweeter i driven by one chanel and the woofer by the other.
    We will design MONO products in the future. It should launch Q1,2020.
  • What Amp/Chip does this use?
    This one using TI3116 works with our DSP together.  amp1.0 using STA326.
  • Hello there, Your products seems ideal for lots of projects. The earlier question was answered my half question. I hope if you make your amp board with 2.1 (subwoofer) speaker out would be more ideal for lots of projects. What is your solution for that now. Please. Thank you.
    Current Up2stream amp 2.0 board got line pin on the board, but required a little hardware DIY skill to use it .It can be used with active subwoofer.  For passive amp support ,we will have future model support that around beginning of 2020.
  • Do you have an available remote control?
    Yes, Up2Stream Amp 2.0 and A50 both support remote controller . For board product ,remote is only available in pacakge price .
  • Does it have a volume knob? Or can you add one?
    Our system support remote controller and app controller .so we don't have volume knob.
  • Hello. Do you have a mounting plate for this amp board? It would be very difficult to install it in DIY project.
    We may launch plate amp in 2020. Currently ,you can try with some of small items firstly :)
  • The Up2Stream Amp 2.0 is nice product! Keep the high end specs, and this module will sell very well. Does the Bluetooth 5.0 possibly have CSR9675 decoding for HD audio? Thanks very kindly, Perry
    we will have complete model with those features soon !
  • Does the multiroom and stereo left/right pairing stay presistent in blueooth mode? My idea is, once I configure my home setup over wifi and connect to one up2stream module over BT will the other modules in other rooms also play and stay in sync or does that feature only work in wifi mode?
    Yes, all music played in our system can be restream to other unit , even in stereo pair mode.
  • Can I purchase all the multi-pin cables from you and at what cost? These are a real pain to find. Thank you.
    yes. we will list the pin cables soon ,those cable normally 1-2 dollars per pcs .
  • Can I purchase the 4-pin line-out from you to drive my subwoofer amplifier in parallel to this amp (driving the mid & tweeters), and at what cost? Thanks kindly.
    If you see our line out pin and know how to use it ,and your subwoofer with filter function ,then it will work .
  • Can it airplay peer to peer like in apple tv without a need for wifi router. I wish to use it in car.
    Yes, our system need a router to work with ,but the router without internet is ok to do airplay .
  • Hi, does this amp sync for multiroom over airplay with appletv or other airplay products? Thx.
    yes .any source our system is playing can be re streamed to other unit in sync
  • multiroom -how many rooms speckers connected with this amplifier
    We have no limit about multiroom connection numbers ,but for play in sync ,we suggest at most 10 rooms
  • Hello, I am interested in building a portable speaker, I have 2 bass of 40w, 2 medium of 20w and 2 twetter of 15w, it is possible to connect everything to the board
    Yes, you can set up them together and our power  output is 50W*2
  • Hello I bought the amplifier without the DC power adapter can I used any DC power adapter with 24 volt? any recommendation? Thank you.
    Yes, 12-26V is fine .
  • I want to build a 2.1 audio system for my deck. I have two sets of speakers and a subwoofer. I've read that timing is everything, and I'm looking for a DIY build where I can control everything digitally. I want to experiment with the 'crossover' frequency between the speakers and the subwoofer (80-100Hz has been recommended). Is this something I can do with your components? If so, what do I need?
    you can try up2stream amp board with line out ,not 2.0 version .
    speaker out connect to your 2.0 stereo system ,and line out to your subwoofer.
Based on 24 reviews Write a review
