Air Motion Transformer (AMT) Tweeters 4 Ohm
Sale price$69.00
5.0
  • HiFi Tweeter, play with clear and detailed sound.
  • 3.3kHz to 40kHz Broad Frequency Range.
  • 25W/35W 4ohm Power Handling. Easy to handle any music scene.
  • 180° Wide Soundstage.
  • Easy to install and full sealing with already mounted EVA.
Model: AMT-7 (Single)
Support Together
Main Features
-HiFiTweeter, play with clear and detailed sound.
-3.3kHz to 40kHz(AMT-7) Broad Frequency Range. 2.3kHz-31kHz(AMT-9)
-25W(AMT-7)/35W(AMT-9) Power Handling. Easy to handle any music scene.
-180°Wide Soundstage.
- Easy to install and full sealing with already mounted EVA.
- Superior black film technology for better look and a clear, more transparent sound.
- Sonically best than the soft dome tweeter and the common yellow film AMT Tweeter.
- Advanced AMT design ""squeezes"" air molecules instead of shoving or crushing them.
- Folded Kapton ribbon diaphragm delivers clean, detailed, and highly dynamic output.
- Powerful, lightweight Neodymium magnet structure for low distortion and high efficiency.
The AMT-7 and AMT-9 Heil AMT Tweeters feature a compact AMT element housed in a round design, offering a wide dispersion of sound that can easily upgrade existing or new speaker designs.
With their small size, they can be used in a variety of speaker projects, including 2-way, 3-way, bookshelf, satellite, center speakers, and boombox.
The attached EVA on the AMT Tweeter ensures a tight seal, optimizing sound quality.
These tweeters utilize premium black film and an advanced AMT design that "squeezes" air molecules to produce clean, detailed, and dynamic treble output with a broad frequency range of up to 40kHz and a wide soundstage.
Additionally, the powerful, lightweight neodymium magnet structure ensuring low distortion and high efficiency.
You can easily replace old tweeters or be integrated into new speaker designs to deliver exceptional audio performance by AMT-7 or AMT-9.
Model
AMT-7
AMT-9
Rated Impedance
4Ω+0/-15%
4Ω+0/-15%
Re
3.3Ω±10%
3.6Ω±10%
RMS Power
15W
20W
Maximal Power
25W
35W
Sensitivity
89dB±2.5dB
92dB±2.0dB
Frequency Range
3.3kHz-40kHz
2.3kHz-31kHz
Lowest Recommend Crossover
≥4.5kHz
≥2.7kHz
Front Panel Material
Aluminum
Aluminum
Diaphragm Material
KAPTON
KAPTON
Conductive Line Material
Alumium foil
Aluminum foil
Magnet Material
Neodymium
Neodymium
Net Weight
88.5g/pc
280g/pc±10%
Build Your New speakers or Revive Your Old Speakers
Bookshelf Speakers
Bookshelf Speakers
Desktop Speakers
Desktop Speakers
Center Speakers
Center Speakers
SPL vs Freq
heil air motion transformer
Air Motion Transformer Tweeter
Based on 1 review
100%
(1)
T
Thomas Gould
Undeniable clarity and quality
I had been told about these type of tweeters years ago, but they were out of my price range. I was blown away to find quality at such a low price. I used these on my 8ohm speaker system by installing a 4 ohm resister in series between my weah 3 way cross over high range output (3.5khz) and the air motion transformer.
I could hear the finest of paper rustling or the clink of silver wear on fine china and could tell the differemce in the quality of the cutlery.. Mind blowing to say the least.
